Millis() not working
I'm writing a code that switches ON led when there is no input and then goes off after 5seconds. I'm using millis() to offer the delay..
The LED instead just lights up and never goes off. Here is the code.
unsigned long previousMillis = 0;        // will store last time LED was updated
const long interval = 5000;           // interval at which to blink (milliseconds)
  pinMode(13, OUTPUT);  //Initialize pin 12 as status LED
  pinMode(7, INPUT);    // Our button pin
  if (digitalRead(7) == LOW)   // Switch is closed to start LED timer
    digitalWrite(13, HIGH);  // LED comes On
  if (currentMillis - previousMillis >= interval)
    digitalWrite(13, LOW);  // LED goes off
Wrong datatype.
What value is the external pullup resistor?
You keep getting a new previousMillis all the while the button is pressed. You want to only do that when the button first becomes pressed. See the State Change Example.
const unsigned long interval = 5000;           // interval at which to blink (milliseconds)
boolean enableTimer = false;
  if (enableTimer == false && digitalRead(7) == LOW)   // Switch is closed to start LED timer
    enableTimer = true;
  if (enableTimer == true && currentMillis - previousMillis >= interval)
I'm not using any pull up resistor
Ah, so your input, the one you test to switch the LED just floats when it’s idle? Waiting for a LOW? What value do you think it floats at?
See here, Switches Tutorial:
https://www.gammon.com.au/forum/?id=11955
What model Arduino are you using?
Tom... :slight_smile:
