servo.write(angle) is non-blocking function. You can use it and then do other tasks
I would like to move wheels of my project that are using servos and the reason of millis() is that I want to move that object forward for a certain period of time. Is that possible with using <Servo.h> ?
Xarakas:
Yes
Have you read Using millis() for timing. A beginners guide ?
What is the model name of the servo motor you are using?
UKHeliBob:
YesHave you read Using millis() for timing. A beginners guide ?
Yes I had. The problem with that is that it keeps doing repetitively and I just want to do it once I call that function, then move on another function e.x...
IoT_hobbyist:
For example another servo moving another part is Micro Servo SG90 (just 180 dregrees would do the thing, but I dont know how to move another part of project and keep moving this part at the same time)
UKHeliBob may have forgotten this, but he once posted the following pseudo-code which I copied into my Arduino "miscellany":
(edit: probably irrelevant since these must be continuous servos, but leaving it here anyway)
UKHeliBob:
....don't move the servos from their current position to their target position all in one command. Move them a little every now and again using millis() for timing. Use a boolean variable to stop them moving when the target position is reachedFor one servo, something like this
start of loop()
get current time from millis()
if current time - previous move time >= wait period and the moving variable is true
move a little
save the time of the move
change the target position a little
if at the target position
set the boolean to false
end if
end if
end of loop()
UKHeliBob:
You can extend this to multiple servos by using arrays for the values and an array of servos
Xarakas:
I'm guessing that you are using "continuous rotation servos" as the drive motors for your wheels.
Yes, you can start moving forward, and then, at a specified time later, do something else.
enum States {Stop, Stopped, MoveForward, MovingForward} State = Stopped;
// Process input here
switch (State)
case Stop:
LeftMotor.write(LeftStop);
RightMotor.write(RightStop);
State = Stopped;
case Stopped:
if (command == "f") // Move forward
State = MoveForward;
case MoveForward:
stateStartTime = millis();
LeftMotor.write(LeftMotorForeward);
RightMotor.write(RightMotorForeward);
State = MovingForward;
case MovingForward:
if (millis() - stateStartTime >= MovingForwardInterval)
State = Stop;
Xarakas:
Of course yes, you can use <Servo.h> library without using delay() and millis() function unless you want to control the speed of motor. See servo tutorial
Thanks guys, I will definitely try this as soon as I come home again. Once again, thank you so much
God bless
IoT_hobbyist:
See servo tutorial
About that:
- Don't power the servo (even a tiny one) from the Arduino 5V
- "Some of Arduino pins can be programmed to generate PWM signal." While that's true for PWM via analogWrite(), it's irrelevant for a servo, and (at least on the Uno pictured) any pin (even, in fact, the analog inputs Ax which are actually digital anyway) can control a servo
> sayHovis:
> About that:
1. See circuit in https://www.arduino.cc/en/Tutorial/Knob. It also powers the motor via Arduino's 5V. It is not a big problem with low-torque motor for learning purpose
2. See the Additional Knowledge part
IoT_hobbyist:
1. See circuit in https://www.arduino.cc/en/Tutorial/Knob. It also powers the motor via 5V. It is not big problem with low-torque motor for learning purpose
- Even an sg90 style servo draws about 750mA at stall so it's never acceptable. Just because the official tutorial here shows it that way, is no reason to perpetuate a bad idea. And I know you said it in the additional info at the bottom: it should be at the top.
- That the library supports 12 servos does of course imply that a pin needn't be a ~PWM (ie analogWrite()) pin since there are only 6, but you also have that only as a footnote. The body of your tutorial gives the distinct impression that a PWM pin is required. It's a pity that tutorials tend for some reason to use pin ~9 which helps perpetuate that thinking.
That silly example is a problem. Well over ninety percent of problems relating to servos posted here are power related and often because the person asking was mislead by that example or others like it.
