Hi guys,
i am trying to make a little and simple program for a greenhouse to plant my orchid.
I tryied many times with millis but i am just going crazy! ![]()
i already setted up separetly all the relays and sensors, everything is working fine but if i can not put all toghether with millis sequence everything would be unuseful ![]()
Please i need your help, maybe or for sure foor you is simple as drinking water but for me is like a mountain.
this is my complete scheme without millis,
can someone help me to put it together and working?
//COMANDI RELATIVI ALL'ACCENDIMENTO E SPEGNIMENTO RELE SERPENTINA (ACCENDI SERPENTINA SE TEMP INFERIORE A 30 GRADI, SPEGNI SE SUPERA I 35
const int VENTOLA =9; //the "s" of relay module attach to CONTROLLO ACCENDI SPEGNI VENTOLA
const int LUCE =7; //the "s" of relay module attach to CONTROLLA ACCENDI SPEGNI LUCE
const int POMPA =8; //the "s" of relay module attach to CONTROLLA ACCENDI SPEGNI POMPA
const int LM35 = 0; // SENSORE LM35 ATTACCATO SU PIN A0 PER CONTROLLARE LA TEMPERATURA
float celsius = 0; // temperature variables
float millivolts; //dichiarazione di variabile tensione (float è per i numeri con la virgola)
int sensor;
const int SERPENTINA = 6; //RELE 6 CONTROLLA LA SERPENTINA
const int LEDSERPENTINA = 10; //LED CONTROLLO ACCENSIONE SERPENTINA PIN 10
Serial.begin(9600); // inizializza la comunicazione seriale
// COMUNICAZIONE CON RELE' E ISTRUZIONI ACCENDI SPEGNI VENTOLE LUCI E ACQUA
pinMode(SERPENTINA, OUTPUT); //RELE CONTROLLO SERPENTINA ACCENDI E SPEGNI SECONDO TEMPERATURE LM35
pinMode(LEDSERPENTINA, OUTPUT); // LED CONTROLLO ACCENSIONE SERPENTINA
pinMode(LUCE, OUTPUT); // CONTROLLO ACCENDI SPEGNI LUCE
pinMode(POMPA, OUTPUT); //CONTROLLO ACCENDI SPEGNI POMPA ACQUA
pinMode(VENTOLA, OUTPUT); //CONTROLLO ACCENDI SPEGNI VENTOLA
digitalWrite(VENTOLA, HIGH); //ACCENDI LA VENTOLA
delay(60000); //TIENILA ACCESA PER 60000 EQUIVALENTE A UN MINUTO
digitalWrite(VENTOLA, LOW); //SPEGNI LA VENTOLA
delay(3540000); //SPEGNI LA VENTOLA PER 3540000 EQUIVALENTE A 59 MINUTI
digitalWrite(LUCE, HIGH); //ACCENDI LA LUCE
delay(64800000); //TIENILA ACCESA PER 64800000 EQUIVALENTE A 18 ORE
digitalWrite(LUCE, LOW); //SPEGNI LA LUCE
delay(21600000); //SPEGNI LA LUCE PER 21600000 EQUIVALENTE A 6 ORE
digitalWrite(POMPA, HIGH); //ACCENDI LA POMPA ACQUA
delay(600000); //TIENILA ACCESA PER 600000 EQUIVALENTE A 10 MINUTI
digitalWrite(POMPA, LOW); //SPEGNI LA POMPA ACQUA
delay(1200000); //SPEGNI LA VENTOLA PER 1200000 EQUIVALENTE A 20 MINUTI
sensor = analogRead(LM35); //lettura valore del sensore LM35 messo sull'ingresso analogico A0
millivolts = ( sensor/1023.0)*5000; //formula per ottenere la tensione di uscita dell'LM35 in millivolts
celsius =millivolts/10; // valore espresso in gradi Celsius (l'out del sensore è 10mv per grado)
Serial.print(celsius);Serial.println(" GRADI"); // stampa su serial monitor del valore di temperatura in gradi Celsius
// accendi il RELE
if (analogRead(LM35)<62) { // 41 corrisponde a 20°C - 62 SONO CIRCA 30 GRADI - QUINDI SE LA TEMPERATURA SCENDE SOTTO I 30 ° ACCENDI IL RELE' SERPENTINA
digitalWrite(SERPENTINA , HIGH);
analogWrite(LEDSERPENTINA, 255); }
if (analogRead(LM35)>72) { // 41 corrisponde a 20°C - 72 SONO CIRCA 35 GRADI QUINDI SE LA TEMPERATURA OLTREPASSA I 35 ° SPEGNI IL RELE' SERPENTINA
digitalWrite(SERPENTINA , LOW);
analogWrite(LEDSERPENTINA, 0);} // SE LA TEMPERATURA OLTREPASSA I 35 SPEGNI IL LED POSIZIONATO IN PIN 10
thanks for your help!
Diego(Milan)
