Hy,so i tried to gasp the millis function usage in codes,but i still have some doubts,can someone help me with these really simple questions:
1.millis acts as counter from when the fist function is run,if we use variable currentmillis = millis,
it just copy the current counter time in that variable,correct?
2.We can replace any delay time or run time by: currentmillis - millis >= delay time.
so in theory any time expressed by milliseconds can be replaced using that function,correct?
3.If i use period = 1 ,will it be able the cop with that small time and not break the code,so it just automatically sets period to milisecond,so i can multiply it with desired time of delay or run of some funcion or statement,correct?
it answers most of my questions but not the main one
If i use period = 1 ,will it be able the cop with that small time and not break the code,so it just automatically sets period to milisecond,so i can multiply it with desired time of delay or run of some function or statement,correct?
If you set period to 1 and use that in the time now minus start time comparison it will provide a 1 millisecond timing period. No problem. No surprise there.
You can multiply the value of period by the required value but why would you ? You might as well just set it to the required period.
I assume that you understand that millis() is not a drop in replacement for delay()
