Hi All
I am having a head scratching moment here with some code. I have an analog hall sensor with Arduino UNO board that is sensing a magnet on a shaft that is rotating at 4-10 rpm. What I am trying to accomplish is slowing the refresh rate down enough to get a good signal and only printing the result every 60 seconds. I know this code has some issues and its not super clean, this is my first full blown attempt at writing code in 20 years.
My issue is when I use 60 sec for the interval, the Serial.print(count) does not show up, if i drop it to 31 sec, I get the RPM = and the correct RPM. What I am concerned about is that if it is 3 or so RPM, that is only 1 - 2 readings to determine the result and it will be a bit wonky. Not a huge issue for this project but I would like to know why this is happening with the interval above 31 sec. Any help is very much appreciated.
ReadAnalogVoltage
Reads an analog input on pin 0, counts changes in A0 pin and counts for 60 seconds to convert into RPM for low speed shafts (1-59)
this will be used for 12-20 hrs at a time in between resets
int threshold;
int thresholdread;
int sensorValueread;
int sensorValue;
int count = 0;
int voltage;
unsigned long previousmillis = 0;
const int interval = 60000;
// the setup routine runs once when you press reset:
int thresholdread = 0;
// initialize serial communication at 9600 bits per second:
// the loop routine runs over and over again forever:
int thresholdread = analogRead(A0); // read sensor for baseline comparison
int threshold = (((thresholdread+49)/50)*50); //round sensor reading to nearest 50 to smooth out readings
delay(1000); // read sensor every 1 second
int sensorValueread = analogRead(A0); //read sensor
int sensorValue = (((sensorValueread+49)/50)*50); //round sensor reading to nearest 50 to smooth out readings
int voltage = sensorValue * (5.0 / 1023.0); //convert sensor reading back into voltage
if (sensorValue > threshold) //test to see if sensor is higher than threshold
count++;} //counts if true
if (sensorValue < threshold) //test to see if sensor is less than threshold
{ count++; //counts if true
Serial.println(voltage); //just for testing purposes
Serial.println(sensorValue); //just for testing purposes
Serial.println(threshold); //just for testing purposes
Serial.println(currentMillis); //just for testing purposes
if ((unsigned long)(currentMillis - previousmillis) >= interval){ //test to see if 30 sec has passed
Serial.print("RPM = ");
Serial.println(count*2,DEC); //counts per minute is equal to RPM
previousmillis = currentMillis; //starts a new 30 sec countdown
count = 0; //resets count to 0 for new countdown
