Millis()
Hi everyone,
I am new to Arduino so my question may seem silly .
I created simple sketch which uses one input pin and one output pin.
While input pin gets high for more than 10000 milli seconds​ output pin gets high.
Sketch logic:-
I defined one unsigned long variable - myvar
If input is low
then myvar = Millie()
If input is high
myvar holds last Millie value.
Then
if Millie() - myvar > 10000
Output turned high
Else
Output turned low.
This works fine. But I don't know what happens while Millis() getting overflow and reset to zero again.
Is my code works during Millis() overflow time????
Always show us your current compete sketch. Use CTRL T to format the sketch. Please use code tags. Use the </> icon in the posting menu. [code] Paste sketch here. [/code]
Read this:
This contains everything you need to know:
(Yes, you were doing it right to begin with.)
The demo Several Things at a Time illustrates the use of millis() to manage timing. It may help with understanding the technique.
...R
