Min and Max reading from analog sensor
Hi to all,
I have to measure some pressure with analog sensor 4-20mA and I need Min and Max reading from it, just to display it.
Now I need your help because I dont know how to start and if this Is a possible to do. Do I need some specila formula to calculate outputValue ?
Second thing is how to get rid of strange signs behind “BAR” on the picture?
Third thing is if can I read the value in 1 or 2 decimals like 100,50 BAR, because now i dont have ?
Below is my curent code:
#include <LiquidCrystal.h>
const int analogInPin = A0;
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
int sensorValue = 0;
int outputValue = 0;
 lcd.begin(40, 4);
 lcd.print("  PRESSURE TESTER  ");
sensorValue = analogRead(analogInPin);
outputValue = ((sensorValue-204)*250)/(1023-204);
if(outputValue>-0.5)
    lcd.setCursor(0,1);
    lcd.print("Sensor 1 = ");
    lcd.print(outputValue);
    lcd.println(" BAR ");
    lcd.setCursor(0,2);
    lcd.print("Pmax = ");
    lcd.setCursor(0,3);
    lcd.print("Pmin = ");
    lcd.setCursor(0,1);
    lcd.println(" Sensor 1 Error "); //Show error if value is less than 4mAmp
    delay(200);        // delay in between reads for stability
lcd.println Could that be your problem?
kikitron:
Create a data structure that holds the current min/max information. Whenever you do a new measurement, check if the value is smaller than min or bigger than max. If so, update accordingly.
EDIT: Something along these lines:
template <class T>
class MinMax
  private:
    T min;
    T max;
  public:
    void initialize(T initialValue)
      min = initialValue;
      max = initialValue;
    void update(T value)
      if(value < min)
        min = value;
      if(value > max)
        max = value;
    T getMin()
      return min;
    T getMax()
      return max;
Use it like this:
// Create a new instance of the MinMax class with the type being int
MinMax<int> sensorMinMax;
// intialize the min/max values to 4 (or your first measurement)
// This is usefull, if your data range is offset from 0. Otherwise the
// minimum value will always stay at 0.
sensorMinMax.initialize(4);
// update the min/max value. After this operation getMin() returns 1
sensorMinMax.update(1);
// update the min/max value. After this operation getMax() returns 5
sensorMinMax.update(5);
