I am having problems with Serial communication on my Mini. I have a Duemilanove 16Mhz and ATmega168 and running my code perfectly but when I switch to my Mini 5v 16Mhz ATmega168 i receive corrupted response.
The Code is:
int incomingByte = Serial.read();
Serial.print(incomingByte,BYTE);
When I run this code on my Duemilanove and send “test” on the Serial line I get “test” back.
But when I do the same on my Mini I get “tecd”. And if I send my name “Daniel” I get “dDab`ellþ” in response.
I have been testing a litle bit more and I think it has to do with the receiving (RX) on the Mini.
When I send characters Serial.print("Daniel"); from the Mini to the pc it works good. I can read on the Serial monitor "Daniel".
When I send Serial.println(Serial.available(),DEC) from the Mini to the pc it is sending me random numbers. If I send "Daniel" from pc to Mini it returns 11 up to 127 and then it resets. Strange.
