Mini Board
Am interested to find a mini arduino board that has bluetooth 5, for mesh network.
Will be using the board to connect sensors such as heart rate, humidity and temperature reading.
Need both 3.3V and 5V supply for these sensor.
Can help check in your inventory is there such features available on mini board, pls.
Rgds
(deleted)
Me thinks Batlady is pulling your leg.
Announced but not shipping until end of July.
https://store.arduino.cc/usa/nano-33-ble-with-headers
If you can widen your thoughts a bit, you might find something like the ESP-01 a good cheap solution.
gbafamily:
Arduino Nano 33 BLE with headers | Arduino Official Store
Note in the tech specs that the board cannot supply 5v unless you are connected to USB and solder bridge a jumper pad on the back of the board. When running off of Vin you will not get any voltage from the 5v pin.
david_2018:
Thanks for pointing out this to me.
Nick_Pyner:
probably try this later. need bluetooth mesh now. thanks
