Motor Spesifications:
Voltage:3.7V-4.2V DC
RPM:55000 RPM
Brushless
0.1A
0.4W
Can I use directly arduino pwm outputs this motor?Are there any motor driver for this motor ?
Please,Help..
RPM:55000 RPM
Brushless
0.1A
0.4W
Please,Help..
This should like one of the slotless coreless brushed DC motors used in mini-drones, and no you
cannot use Arduino pins directly, it likely takes an amp or two under load (the 0.1A is unloaded
current I think). But a single logic-level FET + diode ought to be enough to control it.
mark t any ideas how to controll all four motors ..using arduino and mosfet
Developer29:
BrushlessCan I use directly arduino pwm outputs this motor?Are there any motor driver for this motor ?
Do you have a link to those motors ? Because if they really are "Brushless" then it might be more complicated than you think to drive them.
Steve
