i salvaged this mini graphical LCD from a mp3 player
it has 8 pins to drive it, no chip that i can see, RGB backlight (driven separately on own wires), the graphical resolution was quite good also, tho i have no idea on the pixel dimensions
the board has on it: s442s1lcdv1.2
but googling it has come up with nothing useful.
the mp3 player was powered by 1 AAA battery.
any theories on how it is driven? it would make an awesome project display if i can run it from an arduino board.
and looking at the thing i cannot see a single chip
the screen part itself seems to be connected to the board via 30 or 31 contacts, also there are 9 capacitors on there and what looks like a resistor, tho its under a blob of hot glue that's holding the screen to the board.
Rawr I hate those . You can almost never tell what it is .
Indeed... And it indicates custom circuits, for custom code, that only who made the device know how. I´m right?
It have a black and a red wire at least :P
Maybe wiring Vcc, Gnd and start applying signal to each contact or 2 contacts at once in the all possibilities, maybe some pixel starts show up.
Or if you know how to speak chinese make a call to the producer and ask? (this one was silly) :o
Or maybe you fry the thing :P.
I have no idea if that will hurt the board, but what can it...hurt..? If you can't figure out how to work the darned thing, I would just go with the "Guess and Poke" method haha. ;D
well i managed to carefully remove the glue and under the screen there is no blob, and no chip at all O_o
the wires only power the rgb backlight and are isolated from the board itself.
the only interface for the screen is the 8 pins..
is it some kind of multi/char-plexed display? O_o
so to recap:
8 interface pins, no driver chip, 28 contacts on the screen part itself that are connected (one my or may not be tho), 9 smd caps, 2 smd resistors. thats it..
