Mini Jack audio connection to Arduino Ethernet with PoE module
Hello,
I am new to Arduino stuff. I would like to connect to Arduino Ethernet with PoE module an audio input (from a PC or an Audio Mixer) and do some audio processing.
Is there is any module that can accept mini-jack audio input? Or is there is any guide so i can create my own circuit.
thanks.
Did you want to digitize the audio? The 16 MHz Arduino can acquire only 9259 10-bit samples per second (about 4.6 KHz bandwidth). You can get 76,900 samples per second (~38.5 KHz bandwidth) at lower resolution... how much lower they don't seem to say. :frowning:
Yes i will need to digitize the audio because i will stream it throught the internet using the ethernet.
I would like to give to arduino inputs from an audio mixer output. I believe the 38.5 KHz are ok for my work.
Do you know and module that can accept a mini-jack? or any related work on this field?
thanks
Maybe this would work for you:
http://www.diybin.com/products/Seeedstudio-Music-Shield.html
It can record and play back various data formats.
