marlin code not installing on my Mini Rambo 1.3a board. Getting an error message that 'timeout does not exist or your board not connected'. Even I installed the Rambo USB driver from Ultimachine site then also not happening. Below is the truncated error code due to character restrictions. Full error code is attached (notepad++ file).
Please support.
Thanks,
Gaurav
Arduino: 1.8.1 (Windows 10), TD: 1.36, Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
Sketch uses 77436 bytes (30%) of program storage space. Maximum is 253952 bytes.
Global variables use 2955 bytes (36%) of dynamic memory, leaving 5237 bytes for local variables. Maximum is 8192 bytes.
avrdude: ser_open(): can't open device "\\.\COM3": Access is denied.
avrdude: ser_drain(): read error: The handle is invalid.
avrdude: ser_send(): write error: sorry no info avail
avrdude: stk500_send(): failed to send command to serial port
avrdude: ser_recv(): read error: The handle is invalid.
avrdude: stk500v2_ReceiveMessage(): timeout
the selected serial port avrdude: stk500v2_ReceiveMessage(): timeout
does not exist or your board is not connected
avrdude: stk500v2_getsync(): timeout communicating with programmer
Error_code1.txt (25.6 KB)
