Paul_KD7HB:
Here you have the components right in front of you can probably have them all connected and working and you have to ask the forum is they will run as long as the rocket will fly.
The thing is that I don't have them, and I would like to know if that works before I buy and use them (but if I had sufficient funds to, I would just have tried by myself, don't worry
jremington:
Please post a link to the "supposed" storage device.
That's the whole point of the question, I was wondering if there could be enough memory in the card itself.
jremington:
Consider the SparkFun OpenLog. It consumes very little power, will run on 3V, and no programming other than Serial.print() is required.
I Don't really know what it consists of, as I said, I REALLY am a begginer, but I will certainly consider that
srnet:
AAA Lithium energizers are a far better power supply, light, and will be around 1.5V each for most of their life.
I had no idea at all about that, thanks a lot for the tip !
wvmarle:
You may be able to run the whole contraption off a 3V coin cell, saves you more weight.
The problem here, isn't really the weight, but the size, with a very limited diameter of 3.8 centimeters, but it still seems alright to meFor the storage, I'll try to figure it out later, but I'll keep that in mind
srnet:
Would such a small rocket have a motor powerful enough to lift a 'logger' that would weigh around 20g ?
Yeah, I guess so ^^'
