I am working on a project involving steppers and limit switches.
These switches should be hidden in a 5mm aluminium plate. Therefore I have to find sensors as small as possible. So far, I only found mechanical switches that are 6mm thick. I have read about optical limit sensors that might do the job. Would you have any advice about "ultra miniature sensors" that could be that small and that I could use with an arduino?
Thank you wawa.
Can i use any type of magnet to trigger hall sensors?
Is there any chance to interfere with the signal if aluminium parts are really close?
