Hey Arduino Forum, so I'm planning to build a miniature quadcopter on a budget (around $50). My First Question is will this copter even lift itself off with such small motors. And my other question is if there is a simple quadcopter sketch/library that I can use (preferably compatible with the simple Arduino's and not the Mega's).
HazardsMind:
Also make sure you get two counter rotating props. If all four props are the same, the quad copter with just spin in the air.
Good point... I just thought it. I was kind of dumb thinking that just reversing the + and - in the motor connection will make the propeller spin the other way. Now I realize that this way it will pull down, not up.
But apart from everything, what's your guess? Will it be a success or failure?
I can't really say, you're looking at roughly 150 grams or about 0.33 lbs. How much thrust do those motors provide? I would look into something a little bigger or at least a 3 or 4 bladed prop.
HazardsMind:
They seem more like the tiny propellers found on the tails of small cheap RC helicopters, lol. Finding such information would be very difficult since its from ebay but thanks for the idea.
