My objective: to have an ATMega328P (DIP package) on a breadboard running at 3.3V using the 8MHz internal clock.
My tools: I have an Arduino Uno (SMD version).
Steps taken so far:
I've followed this guide to burn a bootloader to the ATMega328P using my Uno as an ISP. I only deviated from the guide to select 8MHz internal, rather than 16MHz external under Tools > Clock.
I burnt the bootloader and received the output below - looks like it completed successfully.
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\rob_f\Documents\ArduinoData\packages\MiniCore\hardware\avr\2.0.9/avrdude.conf"
Using Port : COM3
Using Programmer : stk500v1
Overriding Baud Rate : 19200
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : STK500
Description : Atmel STK500 Version 1.x firmware
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.03s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "C:\Users\rob_f\Documents\ArduinoData\packages\MiniCore\hardware\avr\2.0.9/bootloaders/optiboot_flash/bootloaders/atmega328p/8000000L/optiboot_flash_atmega328p_UART0_38400_8000000L_B5.hex"
avrdude: writing flash (32768 bytes):
Writing | ################################################## | 100% 0.00s
avrdude: 32768 bytes of flash written
avrdude: verifying flash memory against C:\Users\rob_f\Documents\ArduinoData\packages\MiniCore\hardware\avr\2.0.9/bootloaders/optiboot_flash/bootloaders/atmega328p/8000000L/optiboot_flash_atmega328p_UART0_38400_8000000L_B5.hex:
avrdude: load data flash data from input file C:\Users\rob_f\Documents\ArduinoData\packages\MiniCore\hardware\avr\2.0.9/bootloaders/optiboot_flash/bootloaders/atmega328p/8000000L/optiboot_flash_atmega328p_UART0_38400_8000000L_B5.hex:
avrdude: input file C:\Users\rob_f\Documents\ArduinoData\packages\MiniCore\hardware\avr\2.0.9/bootloaders/optiboot_flash/bootloaders/atmega328p/8000000L/optiboot_flash_atmega328p_UART0_38400_8000000L_B5.hex contains 32768 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.00s
avrdude: verifying ...
avrdude: 32768 bytes of flash verified
avrdude: reading input file "0x0f"
avrdude: writing lock (1 bytes):
Writing | ################################################## | 100% 0.03s
avrdude: 1 bytes of lock written
avrdude: verifying lock memory against 0x0f:
avrdude: load data lock data from input file 0x0f:
avrdude: input file 0x0f contains 1 bytes
avrdude: reading on-chip lock data:
Reading | ################################################## | 100% 0.01s
avrdude: 1 bytes of lock verified
avrdude done. Thank you.
To load the sketch I built the attached circuit. However, because I have an SMD Uno I've connected the Uno reset pin to ground. I've connected the ATMega328P reset (pin 1) to +5V through a 10k resistor with a button to ground it which I press when the upload begins (as described here).
I open the blink example, press upload and receive this:
Arduino: 1.8.13 (Windows Store 1.8.42.0) (Windows 10), Board: "ATmega328, Yes (UART0), EEPROM retained, 328P / 328PA, BOD 2.7V, LTO disabled, Internal 8 MHz"
Access is denied.
exit status 1
Error compiling for board ATmega328.
option enabled in File -> Preferences.
Could someone advise where I might be going wrong please?
