Minimal Arduino?
Hi, does someone have a drawn pic or schematics of a minimum arduino system?
Besides, what IC should i use in Eagle to have an Atmel328 or 168?
Hard to get simpler than this:
http://moderndevice.com/RBBB_revB.shtml
Sparkfun library has the atmegas.
I was actually playing around with just this project to try and learn Eagle some. I followed the sparkfun tutorials, and the part is actually an atmega8 that I just renamed since the pinout is the same. The basic layout I used is from:
http://www.imagearts.ryerson.ca/sdaniels/physcomp/tutorials/Arduino_standalone/ard_hack.html
I just left off the power supply and reset switch.
Here’s what I came up with.
Page 5 of the RBBB PDF has a more complete schematic also:
http://www.moderndevice.com/Docs/RBBB_Instructions_04.pdf
2¢: The crystal and caps, or the resonator can be left out if you use the LilyPad bootloader and run at 8MHz.
Maybe this is a little too simple but I remember somebody starting a thread about a “cheapduino” a while ago…
