I have a sketch that works, finally. I want to use the Atmega chip from an Arduino, loaded with my sketch, to act as a slave I2C device in place of a Microchip 24LC00 EEPROM.
The Question:
What is the MINIMUM amount of hardware I need to make the Atmega function as an I2C chip? Can I just pull the chip off the Arduino, hook up power, ground, SCL and SDA wires (or traces on a board, eventually) and have it work the same way it did on the Arduino board?
In general, an ATmega can get by with regulated 5V and nothing else. Check out this thread.
If you want to get by that way, you need a 16MHz crystal and caps, a regulated voltage source, and pull-up resistor for the reset line. The IC alone won’t work without the support components that it is configured to expect.
The pullup resistor on reset is only neccy when connecting a reset switch (that is connected to ground) to prevent shorting that pin out.
The most minimal setup (w/out changing internal settings of the chip) really just needs a resonator or xtal & 2 caps. Even though Im sure Ive posted this elsewhere before, this is something I wrote up for my class on wiring up a breadboard arduino (assuming that the chip is programmed in the arduino board first):
