In this thread
https://forum.arduino.cc/t/avoid-repeating-a-random-number-within-a-set-time/1033379/
@noiasca kindly shared his code for delivering a set of pseudo random numbers with limited repetition. It worked fine here, both in his Wokwi simulation and when I ran it on a UNO with a low-going button. I've shown his code below, unaltered except that I changed
constexpr uint8_t btn {2};
which I didn't fully understand to
int const btn = 2;
ORIGINAL CODE:
Avoid repeating a random number
items needs to be a lot larger than the size of the used buffer!
const uint8_t items = 42; // items on list
const uint8_t size = 10; // size of ring buffer for already used items
uint8_t used[size]; // stores already used colors
byte index; // ring buffer index
//constexpr uint8_t btn {2};
int const btn = 2;
void initUsed()
for (byte i = 0; i < size; i++)
used[i] = random(0, items); // scramble the content of the array (to allow 0 in the first n trys also)
bool isUsed(byte actual)
bool result = false;
if (actual == used[i]) return true;
return false;
int getRandomNumber()
bool found = false;
int rnd;
while (found == false)
rnd = random(0, items);
if (!isUsed(rnd))
used[index] = rnd;
index++;
if (index >= size) index = 0;
found = true;
return rnd;
void action()
byte actual = getRandomNumber();
Serial.print("index: "); Serial.print(index);
Serial.print("\tactual: "); Serial.print(actual);
delay(100);
Serial.println(F("Random with some uniqueness for the last minutes"));
// randomSeed(analogRead(A4));
randomSeed(analogRead(A0));
pinMode(btn, INPUT_PULLUP);
initUsed();
if (digitalRead(btn) == LOW) action();
However I've been trying for a few hours to adapt it. But I'm unable to see why the code below fails. It does not deliver any printing when the button goes low.
MY CODE
const int btn = 2; // To get the results printed, take button low
int randNumberF = 1; // Temporary for testing
const int bufferSize = 10; // Temp: size of ring buffer for some used tracks
int used[bufferSize]; // Array stores already used tracks
byte index; // Ring buffer index
const int folderSizes[26] {96, 106, 229, 159, 188, 142, 114, 173, 37, 26, 78, 252, 71, 69, 185, 24, 81, 162, 185, 77, 91, 33, 37, 43, 73, 83 };
const int tracks = folderSizes[randNumberF - 1]; // Tracks in the target folder
// Folders are numbered 1 to 26. In this example tracks is therefore 96
// FUNCTIONS ///////////////////////////////////////////
void initUsed()
for (byte i = 0; i < folderSizes[randNumberF - 1]; i++)
// Shuffle the content of the array; allow 0.
used[i] = random(0, tracks);
for (byte i = 0; i < bufferSize; i++)
return false;
bool found = false;
int rnd;
rnd = random(0, tracks);
if (!isUsed(rnd))
used[index] = rnd;
index++;
if (index >= bufferSize) index = 0;
found = true;
return rnd;
void action()
Serial.print("tracks = "); Serial.print(tracks);
delay(100);
delay(200);
Serial.println(F("unique_random-e1"));
initUsed();
