Hello everyone,
I'm working on a robot control project that uses two ESP devices communicating via ESPNOW. One ESP reads input from a gamepad joystick, and the other processes the motor controls. While the system works, I'm experiencing a significant delay of 1-3 seconds during operation, which is affecting performance.
Has anyone encountered a similar issue or found a way to reduce this latency? Would using timing functions like millis() help, or is there another solution to improve the responsiveness of the ESP-NOW communication?
Thanks in advance for any suggestions!
This as tx that reads the gamepad (SENDER)
#include <esp_now.h>
#include <WiFi.h>
#include <ArduinoJson.h>
#include <Bluepad32.h>
// MAC Address ESP Penerima
uint8_t receiverMAC[] = {0xEC, 0x62, 0x60, 0x33, 0xFA, 0xD0};
GamepadPtr myGamepad = nullptr;
// Callback saat gamepad terhubung
void onConnectedGamepad(GamepadPtr gp) {
Serial.println("Gamepad Connected!");
myGamepad = gp;
// Callback saat gamepad terputus
void onDisconnectedGamepad(GamepadPtr gp) {
Serial.println("Gamepad Disconnected!");
// Callback saat ESP-NOW mengirim data
void onSent(const uint8_t *mac_addr, esp_now_send_status_t status) {
Serial.println(status == ESP_NOW_SEND_SUCCESS ? "Sent Successfully" : "Send Failed");
WiFi.mode(WIFI_STA);
if (esp_now_init() != ESP_OK) {
Serial.println("ESP-NOW Init Failed!");
return;
esp_now_register_send_cb(onSent);
esp_now_peer_info_t peerInfo;
memset(&peerInfo, 0, sizeof(peerInfo));
memcpy(peerInfo.peer_addr, receiverMAC, 6);
peerInfo.channel = 0;
peerInfo.encrypt = false;
peerInfo.ifidx = WIFI_IF_STA;
if (esp_now_add_peer(&peerInfo) != ESP_OK) {
Serial.println("Failed to add peer");
return;
BP32.setup(&onConnectedGamepad, &onDisconnectedGamepad);
BP32.update();
if (myGamepad && myGamepad->isConnected()) {
// Ambil data joystick
int xLeft = myGamepad->axisX();
int yLeft = -myGamepad->axisY() + 4;
int z = myGamepad->axisRX();
int btnA = myGamepad->a() ? 1 : 0;
int btnB = myGamepad->b() ? 1 : 0;
// Serialize data ke JSON
StaticJsonDocument<200> doc;
doc["xLeft"] = xLeft;
doc["yLeft"] = yLeft;
doc["z"] = z;
doc["A"] = btnA;
doc["B"] = btnB;
char jsonBuffer[256];
size_t jsonLen = serializeJson(doc, jsonBuffer, sizeof(jsonBuffer));
esp_err_t result = esp_now_send(receiverMAC, (uint8_t *)jsonBuffer, jsonLen);
if (result != ESP_OK) {
Serial.println("Error sending data");
Serial.printf("Sent JSON: %s\n", jsonBuffer);
delay(10);
This as rx which processes the motor (RECEIVER)
#include <WiFi.h>
#define RPWM_PIN1 18
#define LPWM_PIN1 19
#define RPWM_PIN2 21
#define LPWM_PIN2 22
#define RPWM_PIN3 23
#define LPWM_PIN3 25
#define RPWM_PIN4 26
#define LPWM_PIN4 27
void setMotorSpeed(int pin_r, int pin_l, int speed, const char* motorName) {
int pwmValue = abs(speed);
bool maju = (speed > 0);
if (speed == 0) {
analogWrite(pin_r, 0);
analogWrite(pin_l, 0);
Serial.printf("%s: STOP\n", motorName);
analogWrite(pin_r, maju ? pwmValue : 0);
analogWrite(pin_l, maju ? 0 : pwmValue);
Serial.printf("%s: %s dengan PWM %d\n", motorName, maju ? "MAJU" : "MUNDUR", pwmValue);
// Callback saat menerima data
void onReceiveData(const esp_now_recv_info_t *info, const uint8_t *data, int len) {
Serial.print("Data received from: ");
for (int i = 0; i < 6; i++) {
Serial.printf("%02X", info->src_addr[i]);
if (i < 5) Serial.print(":");
// Parsing JSON
DeserializationError error = deserializeJson(doc, data, len);
if (error) {
Serial.print("JSON Parsing failed: ");
Serial.println(error.c_str());
return;
int x = doc["xLeft"] ;
int xLeft = x * -1;
int yLeft = doc["yLeft"];
int z = doc["z"];
int btnA = doc["A"];
int btnB = doc["B"];
Serial.printf("xLeft: %d | yLeft: %d | z: %d | A: %d | B: %d\n", xLeft, yLeft, z, btnA, btnB);
// Hitung kecepatan motor
int m1 = xLeft + yLeft + z;
int m2 = xLeft - yLeft + z;
int m3 = -xLeft + yLeft + z;
int m4 = -xLeft - yLeft + z;
m1 = constrain(m1, -255, 255);
m2 = constrain(m2, -255, 255);
m3 = constrain(m3, -255, 255);
m4 = constrain(m4, -255, 255);
Serial.printf("M1: %d | M2: %d | M3: %d | M4: %d\n", m1, m2, m3, m4);
setMotorSpeed(RPWM_PIN1, LPWM_PIN1, m1, "M1");
setMotorSpeed(RPWM_PIN2, LPWM_PIN2, m2, "M2");
setMotorSpeed(RPWM_PIN3, LPWM_PIN3, m3, "M3");
setMotorSpeed(RPWM_PIN4, LPWM_PIN4, m4, "M4");
delay(10);
pinMode(RPWM_PIN1, OUTPUT);
pinMode(LPWM_PIN1, OUTPUT);
pinMode(RPWM_PIN2, OUTPUT);
pinMode(LPWM_PIN2, OUTPUT);
pinMode(RPWM_PIN3, OUTPUT);
pinMode(LPWM_PIN3, OUTPUT);
pinMode(RPWM_PIN4, OUTPUT);
pinMode(LPWM_PIN4, OUTPUT);
Serial.println("Error initializing ESP-NOW");
return;
esp_now_register_recv_cb(onReceiveData);
