Minimum temperature of Breadboards
Hi, Just wondering if anyone knew what the minimum temperature of a breadboard was, or at least if they will with stand temperatures below freezing (only by a couple of degrees, say -5 degrees centigrade).
Thanks
If there's no mechanical stress or moisture temperature alone wouldn't affect plastic with metal strips in it.
Most of the components you would use on the breadboard however, will only be rated down to 0C.
