Minimum Voltage from datasheet
What would be the minimum voltage for the incoming signal that this IC (lf398) would register? Where can I read this on the datasheet?
datasheet
Thanks!
It depends on your exact circuit, the size of the holding capacitor and how long you want to hold it for. Look at the droop figure in the data sheet.
Never seen one of those ic’s normally I’d use the attached circuit…
