minisumo
i am up to develop mi 1st minisumo using arduino duemilanove
i need advice about:
  1. battery pack: voltage (number of cells?)
  2. Arduino power supply (directly to battery or via voltage regulator?)
  3. motor power supply (L293D is ok? may cause critical noise on power rails?)
thanx
  1. Battery pack size will depend on your motors
  2. Probably best to use a separate battery for the Arduino to avoind problems with noise from the motors.
  3. Choice of H-bridge chip depends on current drain of your motors
Please tell us more about the design! We really need to know the specifications of the motors, at least.
at the time there is not a design and no specifications...
i am trying to organize ideas to make this design :slight_smile:
the idea is to use single supply battery to minimize complexity
so the battery have to feed the arduino and the motors
i think 6 cells (7.2v) could be ok for arduino
motors could be modified servo for continuous rotation or gear motors...
but 7.2 is too much for servos, i have to chose between two setup i think:
  1. battery -> 5v voltage regulator -> servo
    or
  2. battey -> L293 bridge -> gear motors
A single battery will make the robot simpler, but you may find that the Arduino crashes unexpectedly due to noise. But, either of those two schemes should work OK.
probably, using a single supply, the key is to use motors which produce low noise... On other robots i have found that gearmotors based on brushles solar motors are ok and do not disturb micro....
those are very cheap and low torque but works fine
so i will try this way...
btw what is the right strategy to suppress noise on power rails produced by motors? ... other than usual decoupling caps..
Its called a PI filter, so called because it resembles the greak letter. basically, its a inductor in the power line between the motor and arduino, and two caps either side of the inductor, from the supply to ground. Good luck!
excellent tip phill
i will thy this solution
so i have to place a PI filter between Arduino and L293D Supply Voltage pin
well, I have 2 question for you:
  1. On which side of the PI filter have I to connect batteries? (arduino side or motordriver side)
  2. in my bitbox i have two inductors: 22uH and 100uH, which one could be more appropiate for the purpose?
many thanx
up
plz
