I need to have three alarms one minute apart.
The sketch is as follows:
#include "arduino_secrets.h"
/********************* non funziona
Sketch generated by the Arduino IoT Cloud Thing "Untitled"
https://create.arduino.cc/cloud/things/b8b6492c-e136-4705-96e2-a7402e3e023b
Arduino IoT Cloud Variables description
The following variables are automatically generated and updated when changes are made to the Thing
bool alarm_state;
bool led;
Variables which are marked as READ/WRITE in the Cloud Thing will also have functions
which are called when their values are changed from the Dashboard.
These functions are generated with the Thing and added at the end of this sketch.
#include "thingProperties.h"
#include "RTCZero.h"
int hours_alarm = 15;
int minutes_alarm = 40;
int seconds_alarm = 0;
int contatore;
int LED = 2;
RTCZero alarm;
// Initialize serial and wait for port to open:
// This delay gives the chance to wait for a Serial Monitor without blocking if none is found
delay(1500);
// Defined in thingProperties.h
initProperties();
// Connect to Arduino IoT Cloud
ArduinoCloud.begin(ArduinoIoTPreferredConnection);
setDebugMessageLevel(2);
ArduinoCloud.printDebugInfo();
alarm.begin();
led = false;
contatore = 0;
pinMode(LED_BUILTIN, OUTPUT);
pinMode(LED, OUTPUT);
digitalWrite(LED, LOW);
ArduinoCloud.update();
Serial.print(alarm.getHours());
Serial.print(":");
Serial.print(alarm.getMinutes());
Serial.print(":");
Serial.println(alarm.getSeconds());
void onHoursAlarmChange() {
alarm.setAlarmTime(hours_alarm, minutes_alarm, seconds_alarm);
void onMinutesAlarmChange() {
void onSecondsAlarmChange() {
void onAlarmStateChange() {
if (alarm_state == true) {
alarm.enableAlarm(alarm.MATCH_HHMMSS);
alarm.attachInterrupt(alarmMatch);
else {
//alarm.disableAlarm();
led = false;
digitalWrite(LED_BUILTIN, LOW);
void alarmMatch(){
led = true; /7 accende il led
digitalWrite(LED_BUILTIN, HIGH);
Serial.print(contatore);
Serial.println(" : ");
contatore = ++contatore;
Serial.println(contatore);
if(contatore == 1){
//Serial.print(alarm.getHours());
digitalWrite(LED, HIGH);
hours_alarm = 15;
minutes_alarm = ++minutes_alarm;
seconds_alarm = 0;
else if(contatore == 2){
hours_alarm = 15;
seconds_alarm = 0;
else if(contatore == 3){
In the monitor, I do not see the counter incrementing.
It also executes the first of the ifs then by not incrementing the counter it does not execute the subsequent ifs.
Should I enter the new values in the function 'onMinutesAlarmChange()' ?
Where am I going wrong?
EzioGi
