I cant flash the Micro minimOSD with firmware. Tried it with scarab and KV team. OSD shows "waiting for OSD" all the time.
I have tried to clear the EEPROM. Doesnt work!
FTDI is connected to the com4. I have checked it in the device manager.
Settings Arduino:
Board: Arduino pro or pro mini
Prozessor: ATmega328, 5V, 16MHZ
Programmer: AVRIS mkll
Port in my case is COM4
I have connected GND to GND, CTS to GND, VCC to 5V, TX to RX, RX to TX, and DTR to DTR.
The green LED is still blinking.
Blue LED lights solid.
Any ideas?
It has worked before I have made a 4 month break.
Error report of my latest attempt:
Arduino: 1.6.6 (Windows 10), Board: "Arduino Pro or Pro Mini, ATmega328 (5V, 16 MHz)"
Der Sketch verwendet 774 Bytes (2%) des Programmspeicherplatzes. Das Maximum sind 30.720 Bytes.
Globale Variablen verwenden 9 Bytes (0%) des dynamischen Speichers, 2.039 Bytes für lokale Variablen verbleiben. Das Maximum sind 2.048 Bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x18
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x18
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x18
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x18
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x18
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x18
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x18
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x18
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x18
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x18
Problem beim Hochladen auf das Board. Hilfestellung dazu unter http://www.arduino.cc/en/Guide/Troubleshooting#upload.
Dieser Report hätte mehr Informationen mit
"Ausführliche Ausgabe während der Kompilierung"
aktiviert in Datei > Einstellungen.
