I have created a code to generate random frequencies (between 2 values) on pin 9 using tone()
How can I create at same time (i know its not the exact same time, but you know xD) on pin 10 a mirror wave of 9?
I mean, tone() creates for example a 100Hz wave, on pin 9, and what I want is a 100Hz tone, but, moved 180 degrees, when pin 9 is HIGH, pin 10 is LOW, when Pin 9 is LOW, PIN 10 is HIGH.
The tone() function is designed for a single pin. There is no QUICK AND EASY way to have it produce an inverted signal on another pin. The Timer1 hardware in the ATmega328p (UNO, NANO, MINI) can do what you want fairly easily on Pin 9 and Pin 10. Would you like to learn how?
