I've recently tried to connect the ultrasonic sensor to arduino and read the output based on the External Interrupt length. The issue I have is I get an error which looks like this :
avrdude.exe: verification error, first mismatch at byte 0x0200
0x00 != 0x01
avrdude.exe: verification error; content mismatch
avrdude.exe: safemode: Fuses OK (E:FD, H:D8, L:FF)
I have no clue what that means.
I'm guessing it may have to do with these few lines of code :
ldi r16, 0x01
STS EICRA, r16 ; make INT0 rising edge triggered
clr r16
ldi r16, 0x01
OUT EIMSK, r16 ; enable INT0 interrupt
SEI ; enable interrupts
clr r16
There was/is a problem with the Mega boot loader if your sketch contains three exclamation marks in a row. So I to not think that this is cause by the code snippet that you posted.
.ORG 0
JMP MAIN
.ORG 0x02 ; vector interrupt for INT0 = 0x02
call int_detect_wave_from_sensor
.ORG 0x100 ; ommit first 100 addresses left for interrupts
LDI R16, HIGH(RAMEND)
OUT SPH, R16
LDI R16, LOW(RAMEND)
OUT SPL, R16 ; initialize stack pointer
clr r16
ldi r16, 0xFF ;
out DDRA, r16 ; port A output
ldi r16, 0x00
out DDRD, r16 ; port D input
ldi r16, 0x01
clr r16
ldi r16, 0x01
clr r16
;----- start main
main :
ldi r16, 1<<PA0
out PORTA, r16 // Send HIGH on PA0 to start the detect and PROBABLY start interrupt
ldi r16, 0
out PORTA, r16 // clear the PA0
clr r16
call delay_detection_60ms
rjmp main
; ----- end main
delay_detection_60ms: ; delay 60ms for the sensor accurate response
ldi r17, 250
again:
dec r17 ; 1 c
brne again ; 2c
ldi r17, 80
again2:
dec r17
brne again2
ret
int_detect_wave_from_sensor:
ldi r19, 1<<PA2 ; high on PA2 for buzzer
out PORTA, r19
call delay_detection_60ms ; just a random delay that would put buzz at least for 60ms
clr r19
reti
This is the whole code. At this point I am only trying to get any kind of response from the sensor
Does the same error occur if you upload the bare minimum sketch you get via File > New, or does it only happen when you post the specific code you shared above?
I fixed it. The problem is I used .ORG 100 in the code, which seems to override some of the registers I was working with there. I changed it to .ORG 400 and it all runs perfect
