Missing first character on screen
Hi all, I now have a problem trying to get my text to show the first character. For example, if i set the force as 100 it will only read 00. everything's working fine normally i would just put a space in front of my text however, i can't do it this time becsause i'm displaying a variable.
thanks
  #include <Wire.h>
  #define LCD05  0x63                   // LCD05 address
  char stringBuf[20];
  char stringBuf1[4];
  byte buffer[4];
  // constants won't change. They're used here to
  // set pin numbers:
  const int buttonPin1 = 11;     // the number of the pushbutton pin
  const int buttonPin2 = 10;
  const int buttonPin3 = 9;
  const int buttonPin4 = 8;
  // variables will change:
  int buttonState1 = 0;         // variable for reading the pushbutton status
  int buttonState2 = 0;
  int buttonState3 = 0;
  int buttonState4 = 0;
  int force = 100;
  delay(100);                          // Delay to wait for everything to power up
  // initialize the pushbutton pin as an input:
  pinMode(buttonPin1, INPUT);
  pinMode(buttonPin2, INPUT);
  pinMode(buttonPin3, INPUT);
  pinMode(buttonPin4, INPUT);
  Wire.begin();
  buffer[0] = 0;                       // Clear the screen
  buffer[1] = 12;
  buffer[2] = 19;
  buffer[3] = 31;
  buffer[4] = 10;
  Wire.beginTransmission(LCD05);
  Wire.write(buffer,5);
  Wire.endTransmission();
  while (buttonState1 == LOW){
buttonState1 = digitalRead(buttonPin1);
buttonState2 = digitalRead(buttonPin2);
buttonState3 = digitalRead(buttonPin3);
buttonState4 = digitalRead(buttonPin4);
  if (buttonState3 == HIGH){
    force = force +1;
  if (buttonState4 == HIGH){
    force = force -1;
//    if (force <= 0){
  //    force = 0;
  Wire.begin();
  buffer[1] = 19;
  buffer[2] = 3;
  buffer[3] = 3;
  buffer[4] = 1;
  String message1 = "   ";      // The message to be put on the screen
  int len1 = message1.length() + 1;       // Length of the message
  message1.toCharArray(stringBuf, len1);  // Convert the message to a car array
  stringBuf[0] = 0;                     // First byte of message to 0 (LCD05 command register)
  Wire.write(stringBuf, len1);
  Wire.begin();
  buffer[0] = 0;
  buffer[1] = 19;
  buffer[2] = 3;
  buffer[3] = 3;
  buffer[4] = 15;
      String displayforce = String(force);    // The message to be put on the screen
 int len2 = displayforce.length() + 1;       // Length of the message
  displayforce.toCharArray(stringBuf1, len2);  // Convert the message to a car array
  //itoa(force,stringBuf1,5);
//  stringBuf1[0] = 0;                     // First byte of message to 0 (LCD05 command register)
  Wire.write(stringBuf1, len2);
  delay(150);
byte buffer[4];
Creates an array of 4 bytes.
  buffer[1] = 12;
  buffer[2] = 19;
  buffer[3] = 31;
  buffer[4] = 10;
That's 5 bytes, the last one
buffer[4]
will be in memory used for something else and will corrupt it.
If you create an array with 4 bytes then the are:
[0], [1], [2], [3]. There is no [4]
Futher on you use
[1] to [4]
instead of
[0] to [3]
I've tried this but still having no luck :(.
 #include <Wire.h>
  char stringBuf[20];
  char stringBuf1[4];
  byte buffer[4];
  // set pin numbers:
  int force = 100;
  Wire.begin();
  buffer[0] = 12;                       // Clear the screen
  buffer[1] = 19;
  buffer[2] = 31;
  buffer[3] = 10;
  Wire.write(buffer,4);
    force = force +1;
    force = force -1;
//    if (force <= 0){
  //    force = 0;
  Wire.begin();
  buffer[1] = 19;
  buffer[2] = 3;
  buffer[3] = 3;
  buffer[4] = 1;
  Wire.begin();
  buffer[0] = 19;
  buffer[2] = 3;
  buffer[3] = 3;
  buffer[4] = 15;
  delay(150);
Wire.begin();
  buffer[0] = 19;
  buffer[1] = 3;
  buffer[2] = 3;
  buffer[3] = 1;
  String message1 = "  hi ";      // The message to be put on the screen
You've not done what I said.
If I change byte buffer it either doesn't change at all or it stays the same same goes for all the other buffers if I change them starting from 0 instead of 1.
You still have at least one instance of:
  buffer[4] = 1;
In your code. I don't know if that's your only problem but while there is an obvious thing that's wrong it doesn't make any sense to look elsewhere for problem.
A hint, print the space before you print the variable. If you are worried about buffer size add 1 to it but it appears you know about zero. This response is to help you get started in solving your problem, not solve it for you.
Good Luck & Have Fun!
Gil
Hi all, I'm having trouble displaying my variable. Normally if I wanted to display a message all I would have to do is add a space in front then the message and then it reads fine. So what I'm trying to do is add a space before a variable so that when I want the variable "Force" to display 100 it doesn't just read 00 it will have the first character of 100.
How would I go about doing this without adding numbers in front because ill need to use the overall number later on to do some equations.
Thanks
Normally, numeric variables don't have embedded spaces in them. Only when you come to print them in some way, do you start formatting them to display nicely.
Functions like snprintf() can be used for extensive formatting of numbers.
Maybe post the code you are having trouble with and say how the output should appear.
Topics merged
 #include <Wire.h>
  char stringBuf[24];
  char stringBuf1[24];
  byte buffer[4];
  // set pin numbers:
  int force = 100;
  Wire.begin();
  buffer[0] = 24;
  buffer[1] = 4;                      // Clear the screen
  buffer[2] = 19;
  buffer[3] = 31;
  buffer[4] = 150;
    force = force +1;
    force = force -1;
   if (force <= 0){
     force = 0;
  Wire.begin();
  buffer[1] = 19;
  buffer[2] = 3;
  buffer[3] = 3;
  buffer[4] = 1;
  String message1 = "  100 ";      // The message to be put on the screen
  Wire.begin();
                       // Clear the screen
  buffer[0] = 19;
  buffer[1] = 3;
  buffer[2] = 3;
  buffer[3] = 5;
  buffer[4] = 31;
  buffer[5] = 150;
  Wire.write(buffer,6);
  //stringBuf1[0] = 0;
  delay(150);
Wire.begin();
  buffer[0] = 19;
  buffer[1] = 3;
  buffer[2] = 3;
  buffer[3] = 1;
Please edit your post and put the code in code tags.
You obviously know how to do it because you did it in post #2
What does the code do ?
What should it do ?
I have hidden most of the code to make the part I'm looking at easier and less confusing which is what the /* is for
Go on. It is easy enough for you to remove redundant lines and format nicely with ctrl-T
Making that tiny effort makes all the difference to any reader response.
David.
