Hello
I have just bought an Uno R4 Wifi and having difficulty compiling. It appears I have a missing file in Arduino/libraries/hardware. Would be grateful for some help. Here is the log.
FQBN: arduino:renesas_uno:unor4wifi
Using board 'unor4wifi' from platform in folder: C:\Users\Nigel\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.0.2
Using core 'arduino' from platform in folder: C:\Users\Nigel\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.0.2
loading library from c:\Users\Nigel\Documents\Arduino\libraries\hardware: invalid library: no header files found
I then get 100+ lines showing that key defines are not set up.
Here are the last few lines.
c:\Users\Nigel\Documents\Arduino\libraries\Elegoo_TFTLCD\pin_magic.h:384:33: note: suggested alternative: 'bitSet'
#define CD_DATA *cdPort |= cdPinSet
c:\Users\Nigel\Documents\Arduino\libraries\Elegoo_TFTLCD\Elegoo_TFTLCD.cpp:1093:3: note: in expansion of macro 'CD_DATA'
CD_DATA;
c:\Users\Nigel\Documents\Arduino\libraries\Elegoo_TFTLCD\pin_magic.h:386:33: error: 'csPinSet' was not declared in this scope
#define CS_IDLE *csPort |= csPinSet
c:\Users\Nigel\Documents\Arduino\libraries\Elegoo_TFTLCD\Elegoo_TFTLCD.cpp:1102:3: note: in expansion of macro 'CS_IDLE'
CS_IDLE;
c:\Users\Nigel\Documents\Arduino\libraries\Elegoo_TFTLCD\pin_magic.h:386:33: note: suggested alternative: 'bitSet'
CS_IDLE;
Using library Elegoo GFX Library at version 1.0.2 in folder: C:\Users\Nigel\Documents\Arduino\libraries\Elegoo_GFX_Library
Using library Elegoo_TFTLCD in folder: C:\Users\Nigel\Documents\Arduino\libraries\Elegoo_TFTLCD (legacy)
Using library TouchScreen in folder: C:\Users\Nigel\Documents\Arduino\libraries\TouchScreen (legacy)
exit status 1
Compilation error: exit status 1
