Missing Library, BUT I have the library. No Spelling mistakes. Library is Open in IDE
I'll try to give as much information as I can.
I have been given a code saying it would not compile. I checked it and it shows that its missing libraries. (I2SMEMSSampler.h)
The required Libraries cannot be found in the Library Manager.
I found the complete code on GitHub, It has all the custom libraries in it.
I copied all the libraries in that GitHub folder into my sketch folder, Now when I open the *.ino file, the library files (I2SMEMSSampler.h) open up in the Arduino IDE as separate tabs. When I Hover over the Code where the library is included (On #include <I2SMEMSSampler.h>) , it opens a pop up saying where the library is located. (Shouldn't that mean it has found and recognized the library?)
But when I compile the code it gives the same error code saying the Library is missing. I CAN SEE THAT THE LIBRARY IS THERE. It's open in the IDE as well as a separate tab.
The error is frustrating me. I'm sure I'm missing something, but for the life of me I cannot figure it out.
So Far I've tried copying the files to the main Arduino libraries folder, I've copied them into the sketch folder, I've tried installing other libraries from the library manager which might be related to the one I need, Nothing has worked.
The Error code:
Using board 'esp32' from platform in folder: C:\Users\Shah\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6
Using core 'esp32' from platform in folder: C:\Users\Shah\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6
cmd /c if exist "C:\\Users\\Shah\\Desktop\\New folder (2)\\CodeVentxCasefinal\\partitions.csv" copy /y "C:\\Users\\Shah\\Desktop\\New folder (2)\\CodeVentxCasefinal\\partitions.csv" "C:\\Users\\Shah\\AppData\\Local\\Temp\\arduino-sketch-C1A18179FF5CD69E25FB335DFDB8ACF8\\partitions.csv"
        1 file(s) copied.
cmd /c if not exist "C:\\Users\\Shah\\AppData\\Local\\Temp\\arduino-sketch-C1A18179FF5CD69E25FB335DFDB8ACF8\\partitions.csv" copy "C:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6\\tools\\partitions\\default.csv" "C:\\Users\\Shah\\AppData\\Local\\Temp\\arduino-sketch-C1A18179FF5CD69E25FB335DFDB8ACF8\\partitions.csv"
Detecting libraries used...
"C:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/config" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_trace" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_update" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/asio" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bootloader_support" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bt" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/coap" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/console" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/driver" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/efuse" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-tls" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_event" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_client" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_server" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_server" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/espcoredump" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ethernet" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/expat" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fatfs" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freemodbus" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freertos" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/heap" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/idf_test" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/jsmn" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/json" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/libsodium" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/log" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/lwip" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mbedtls" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mdns" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/micro-ecc" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mqtt" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/newlib" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nghttp" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nvs_flash" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/openssl" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protobuf-c" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protocomm" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/pthread" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/sdmmc" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/soc" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spi_flash" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spiffs" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcp_transport" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ulp" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/unity" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/vfs" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wear_levelling" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32-camera" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6\\cores\\esp32" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6\\variants\\esp32" "C:\\Users\\Shah\\AppData\\Local\\Temp\\arduino-sketch-C1A18179FF5CD69E25FB335DFDB8ACF8\\sketch\\CodeVentxCasefinal.ino.cpp" -o nul
Alternatives for FreeRTOS.h: [BLE@1.0.1]
ResolveLibrary(FreeRTOS.h)
  -> candidates: [BLE@1.0.1]
"C:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/config" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_trace" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_update" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/asio" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bootloader_support" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bt" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/coap" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/console" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/driver" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/efuse" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-tls" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_event" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_client" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_server" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_server" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/espcoredump" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ethernet" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/expat" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fatfs" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freemodbus" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freertos" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/heap" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/idf_test" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/jsmn" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/json" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/libsodium" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/log" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/lwip" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mbedtls" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mdns" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/micro-ecc" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mqtt" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/newlib" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nghttp" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nvs_flash" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/openssl" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protobuf-c" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protocomm" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/pthread" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/sdmmc" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/soc" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spi_flash" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spiffs" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcp_transport" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ulp" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/unity" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/vfs" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wear_levelling" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32-camera" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6\\cores\\esp32" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6\\variants\\esp32" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6\\libraries\\BLE\\src" "C:\\Users\\Shah\\AppData\\Local\\Temp\\arduino-sketch-C1A18179FF5CD69E25FB335DFDB8ACF8\\sketch\\CodeVentxCasefinal.ino.cpp" -o nul
Alternatives for I2SMEMSSampler.h: []
ResolveLibrary(I2SMEMSSampler.h)
  -> candidates: []
C:\Users\Shah\Desktop\New folder (2)\CodeVentxCasefinal\CodeVentxCasefinal.ino:4:28: fatal error: I2SMEMSSampler.h: No such file or directory
compilation terminated.
Using library BLE at version 1.0.1 in folder: C:\Users\Shah\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\libraries\BLE
exit status 1
Compilation error: I2SMEMSSampler.h: No such file or directory
Please post a link to where you found it.
This is an odd result from the language server. I can reproduce it.
The language server is a separate system from the library discovery system of the Arduino sketch preprocessor that finds the library for the compiler. This #include directive syntax:
Tells the library discovery system and compiler to look in the include paths for that file. However, the file is not in the include paths because you have used a non-standard approach to installing the library:
The sketch folder is not in the include paths, so it is normal and expected that this file will not be found.
There is an alternative #include directive which indicates that the local path should be first searched for the file, falling back to the include paths if it is not found there:
#include "I2SMEMSSampler.h"
This is the syntax you must use for #include directives of header files that are in the sketch folder.
So you have two options to fix the issue:
  • Install the library normally
  • Change all #include directives to use the double quotes syntax.
I recommend the first of these options. In some cases, it can be useful to bundle libraries with a sketch, but it also is more complicated so I would avoid it unless you have a specific reason for doing that.
I see you have already attempted a normal library installation:
You must make sure the files are installed to the right location. It is not possible to determine whether or not you did that without more details, but the fact that the error still occurs indicates that they may not have been installed correctly.
The most common cause of problems with a manual library installation is that the library is a folder and that folder must be installed under the libraries subfolder of your sketchbook folder. Your description "copying the files" makes it sound like maybe you copied the library's files directly under the libraries folder. That won't work.
I'll provide detailed installation instructions as soon as you tell us the link to the library on GitHub. If you would like to look at some general instructions for manual library installation, they are available here:
https://docs.arduino.cc/software/ide-v1/tutorials/installing-libraries#manual-installation
Be careful about this sort of "shotgun" approach to solving problems. If you aren't methodical, you might end up stacking up a list of problems that you will have difficulty backing your way out of once you get back on the right track.
GitHub - atomic14/esp32_sdcard_audio: A simple example that shows how to record a WAV file to an SD Card on the ESP32
Thank you so much for enlightening me, I had no idea about the language server and library discovery system.
I have tried using the double quote syntax before, But I'm going to give that another try. Hopefully that works. I've since restarted my PC aswell (That may seem too simple, But somehow it has worked for me many times before)
I'll give that a try again as well if the other option didn't work.
I studied the structure of the default libraries installed into Arduino, and made sure that the ones I manually installed follow the same folder structure. However, I will also re-do that whole process from scratch because I've deleted them considering that there might be a conflict.
I'm going to give this a thorough read as well.
I know it wasn't a very good approach, But I did it as a last hail mary attempt. I did proceed to uninstall those as soon as it didn't work.
Lastly, I really want to thank you from the bottom of my heart for finding the time to reply and help in fixing my problem.
Oof. I see this is quite a challenging thing to use with Arduino. The problem is the author of the project created it for use with the alternative PlatformIO development tool:
PlatformIO supports standard Arduino libraries, so the project author could have made it to work with both Arduino IDE and PlatformIO, but unfortunately they instead used a format that is not compatible with Arduino IDE.
It is possible to convert this to an Arduino library, but it looks quite challenging. You are probably best off to just use PlatformIO instead.
THIS WORKED. I CANNOT THANK YOU ENOUGH.
I see what i did wrong here the first time i did it, I did not include these libraries into the sketch folder.
You are a life saver.
However, I have run into a new problem now as the code proceeded to compile.
Bear in mind i have only included the part where errors show up. Otherwise it is too long to post.
C:\Users\Shah\Desktop\New folder (2)\CodeVentxCasefinal\CodeVentxCasefinal.ino:22:49: error: 'void record(I2SSampler*, const char*)' redeclared as different kind of symbol
 void record(I2SSampler *input, const char *fname)
C:\Users\Shah\Desktop\New folder (2)\CodeVentxCasefinal\CodeVentxCasefinal.ino:18:5: note: previous declaration 'int record'
 int record=0;
C:\Users\Shah\Desktop\New folder (2)\CodeVentxCasefinal\CodeVentxCasefinal.ino: In function 'void record(I2SSampler*, const char*)':
 int record=0;
"C:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/config" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_trace" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_update" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/asio" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bootloader_support" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bt" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/coap" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/console" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/driver" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/efuse" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-tls" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_event" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_client" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_server" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_server" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/espcoredump" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ethernet" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/expat" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fatfs" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freemodbus" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freertos" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/heap" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/idf_test" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/jsmn" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/json" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/libsodium" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/log" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/lwip" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mbedtls" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mdns" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/micro-ecc" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mqtt" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/newlib" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nghttp" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nvs_flash" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/openssl" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protobuf-c" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protocomm" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/pthread" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/sdmmc" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/soc" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spi_flash" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spiffs" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcp_transport" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ulp" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/unity" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/vfs" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wear_levelling" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32-camera" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -MMD -c -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6\\cores\\esp32" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6\\variants\\esp32" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6\\libraries\\BLE\\src" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6\\libraries\\SPIFFS\\src" "-IC:\\Users\\Shah\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6\\libraries\\FS\\src" "C:\\Users\\Shah\\AppData\\Local\\Temp\\arduino-sketch-C1A18179FF5CD69E25FB335DFDB8ACF8\\sketch\\Output.cpp" -o "C:\\Users\\Shah\\AppData\\Local\\Temp\\arduino-sketch-C1A18179FF5CD69E25FB335DFDB8ACF8\\sketch\\Output.cpp.o"
C:\Users\Shah\Desktop\New folder (2)\CodeVentxCasefinal\CodeVentxCasefinal.ino: In function 'void loop()':
C:\Users\Shah\Desktop\New folder (2)\CodeVentxCasefinal\CodeVentxCasefinal.ino:109:8: error: 'output' was not declared in this scope
   play(output, "/sdcard/tone.wav");
C:\Users\Shah\Desktop\New folder (2)\CodeVentxCasefinal\CodeVentxCasefinal.ino:111:10: error: 'input' was not declared in this scope
   record(input, "/sdcard/recorded.wav");
C:\Users\Shah\Desktop\New folder (2)\CodeVentxCasefinal\CodeVentxCasefinal.ino:111:39: error: 'record' cannot be used as a function
C:\Users\Shah\Desktop\New folder (2)\CodeVentxCasefinal\CodeVentxCasefinal.ino: In function 'void Read_Button()':
C:\Users\Shah\Desktop\New folder (2)\CodeVentxCasefinal\CodeVentxCasefinal.ino:134:16: error: 'output' was not declared in this scope
         { play(output, "/sdcard/recorded.wav"); }
C:\Users\Shah\Desktop\New folder (2)\CodeVentxCasefinal\CodeVentxCasefinal.ino: In function 'void Read_Sensor()':
C:\Users\Shah\Desktop\New folder (2)\CodeVentxCasefinal\CodeVentxCasefinal.ino:165:17: error: 'output' was not declared in this scope
         {  play(output, "/sdcard/standard.wav");
C:\Users\Shah\Desktop\New folder (2)\CodeVentxCasefinal\CodeVentxCasefinal.ino:171:17: error: 'output' was not declared in this scope
Using library SPIFFS at version 1.0 in folder: C:\Users\Shah\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\libraries\SPIFFS
Using library FS at version 1.0 in folder: C:\Users\Shah\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\libraries\FS
exit status 1
Compilation error: 'void record(I2SSampler*, const char*)' redeclared as different kind of symbol
I am looking into the errors in more detail, but I have no clue about the last line.
I have no idea what PlatformIO IDE is, And how to use it. But it's never too late to learn. Can you tell me if Visual Studio can upload sketches to boards like Arduino?
I realise this may be a stupid question to ask, but “If you ask a stupid question, you may feel stupid; if you don't ask a stupid question, you remain stupid .” - Mark Twain (Probably)
This line:
Is just a copy of the first error encountered by the compiler. The full error message makes the problem more clear:
So you have a function named record in your sketch, declared at line 22
You also have a variable named record in the same scope, declared at line 18. You need to change either the function or the variable name so that they are each unique. That will fix the error.
Well, it seems you were able to figure out how to use this library with Arduino IDE after all, in which case it is not necessary.
Yes. There is an extension that is intended to provide Arduino support to Visual Studio:
https://www.visualmicro.com/
Microchip, the manufacturer of the AVR and ATSAMD chips on some of the most popular boards provides a "Microchip Studio" IDE that is based on Visual Studio. This supports the microcontrollers on those boards, but does not support the Arduino framework, so you would use it to do lower level programming of these boards:
Similar IDEs may be available for other microcontrollers found on Arduino boards.
In case you meant "Visual Studio Code" instead of "Visual Studio", the answer is also yes. Microsoft provides an Arduino extension for VS Code:
PlatformIO also provides an extension for VS Code:
https://docs.platformio.org/en/stable/integration/ide/vscode.html
I figured out the error. Changed the variable names. And it worked. Then got another error. Then fixed that. Then another. And so on. Now I'm fixing those errors. This seems hopeless. I don't know how many of these errors are left. Maybe re-writing the entire thing seems more logical than working on someone else's code.
Thank you for your immense help, I learned quite a lot from this small interaction with you, and I am very thankful to you for that.
