tom321
November 8, 2022, 5:50am
1
Hi
Magn is missing on serial plotter, where is the error?
//https://github.com/curiores/ArduinoTutorials/blob/main/BasicFilters/ArduinoImplementations/LowPass/SimpleExamples/butterworth2.ino
int Magn ;
//Ux
float input_voltage = 0.0;
float x[] = {0, 0, 0};
float y[] = {0, 0, 0};
int k = 0;
//Uy
float input_voltage2 = 0.0;
float x2[] = {0, 0, 0};
float y2[] = {0, 0, 0};
int k2 = 0;
pinMode(PA8, PWM);
pinMode(PA9, PWM);
TIMER1_BASE->CCER = (1 << 4) | (1 << 0); //cc1e/cc2e enable
TIMER1_BASE->CCMR1 = (1 << 13) | (1 << 12) | (1 << 5) | (1 << 4); //toogle mode
TIMER1_BASE->PSC = 0;
//TIMER1_BASE->ARR=2879;
TIMER1_BASE->ARR = 1181 * 2; // 15.2kHz
TIMER1_BASE->CCR1 = 0 ;
//TIMER1_BASE->CCR2=1439 ;//
TIMER1_BASE->CCR2 = 1181 ;
TIMER1_BASE->CR1 = 1;
// Ux
int analog_value = analogRead(PA0); // Ux
int analog_value2 = analogRead(PA1);//Uy
//Ux
input_voltage = (analog_value * 5.0) / 1024.0;
x[0] = input_voltage;
input_voltage2 = (analog_value2 * 5.0) / 1024.0;
x2[0] = input_voltage2;
//Ux
float b[] = {0.00024132, 0.00048264, 0.00024132};
float a[] = {1.95558189, -0.95654717};
y[0] = a[0] * y[1] + a[1] * y[2] +
b[0] * x[0] + b[1] * x[1] + b[2] * x[2];
//Uy
float b2[] = {0.00024132, 0.00048264, 0.00024132};
float a2[] = {1.95558189, -0.95654717};
y2[0] = a2[0] * y2[1] + a2[1] * y2[2] +
b2[0] * x2[0] + b2[1] * x2[1] + b2[2] * x2[2];
if (k % 3 == 0)
Magn = sqrt(pow((2 * y[0]), 2) + pow(2 * y2[0], 2) );
Serial.print(" Magn =");
Serial.print(Magn);
Serial.print(" Uxf = ");
Serial.print(2 * y[0]); // Ux filtered
Serial.print(" Uyf = ");
Serial.print(2 * y2[0] + 5); // Uy filtered
delay(1); // Wait 1ms
for (int i = 1; i >= 0; i--) {
x[i + 1] = x[i]; // store xi
y[i + 1] = y[i]; // store yi
k = k + 1;
x2[i + 1] = x2[i]; // store x2i
y2[i + 1] = y2[i]; // store y2i
k2 = k2 + 1;
Should this not be
(k % 3 == 0)
tom321
November 8, 2022, 6:37am
3
I changed = no different.
if (k % 3 == 0)
Serial.print(Magn);
On serial monitor I have it but is missing in serial plotter.
Hi @tom321 .
You are using an inconsistent and non-standard data format. It is amazing you are getting anything at all in the plotter.
Try it again after changing your sketch to use a supported data format like this:
Uxf:11,Uyf:42,Magn:123
tom321
November 8, 2022, 7:28am
5
//Magn = sqrt(pow((2 * y[0]), 2) + pow(2 * y2[0], 2) );
// Serial.print(" Uxf = ");
// Serial.print(2 * y[0]); // Ux filtered
// Serial.print(" Uyf = ");
// Serial.print(2 * y2[0] + 5); // Uy filtered
Serial.println(33);
// Serial.println();
serial monitor is printing 33 serial plotter this
You are still not using a supported data format.
Please look very carefully at the example data I provided in my previous reply. If you are having difficulty modifying your sketch to use that format, just let us know exactly where you are stuck and we'll help you out.
tom321
November 8, 2022, 5:45pm
8
oqibidipo:
Add a space after the =.
Thanks, you solved the problem.
Please note this is not a supported data format. It might happen to work now, but there is no guarantee it will continue to work. In fact, it will not work if you use Arduino IDE 2.x.
b707
November 8, 2022, 11:08pm
10
Serial plotter requires a space between "=" sign and a value.
So you need edit the line
tom321:
writing it as:
Serial.print(" Magn = ");
The Serial Plotter data format is documented here:
https://github.com/arduino/Arduino/blob/master/build/shared/ArduinoSerialPlotterProtocol.md#serialplotter-protocol
The first thing I should state is that there are inaccuracies in this documentation. Unfortunately the people who wrote it and accepted it didn't bother to actually verify that the information was accurate. For this reason, it claims support for spaces in label names when in fact such label names were not supported from the very start.
But beyond that detail, other information provided there is sound.
Note that nowhere in the documentation does it mention support for = as a label-value separator. The only supported label-value separator is :
I don't understand why everyone here is so set on using an unsupported format.
b707
November 9, 2022, 12:03am
12
Not everyone, but OP only.
The OP is using the incorrect format, but it occasionally works for him.
So it's easier to tell him to add a single space between the "=" and the data than to explain that he's got it completely wrong
I disagree. The code changes required to do it right are utterly trivial. So why not do it right?
system
Closed
May 8, 2023, 12:05am
14
