Hi, I would like to know if where am I missing something because I have this code, and after the first loop the program wont Proceed. I suspect that it is on the disabling of the CS/SS of the shield(maybe not or another probable cause). So here's the code
#include <Adafruit_CC3000.h>
#include <ccspi.h>
#include <SPI.h>
#include <string.h>
#include "utility/debug.h"
#include "RTClib.h"
#include <SD.h>
#include <Wire.h>
#include <Thread.h>
#include <ArduCAM.h>
#include "memorysaver.h"
#define ADAFRUIT_CC3000_IRQ 3
#define ADAFRUIT_CC3000_VBAT 5
#define ADAFRUIT_CC3000_CS 10
Adafruit_CC3000 cc3000 = Adafruit_CC3000(ADAFRUIT_CC3000_CS, ADAFRUIT_CC3000_IRQ, ADAFRUIT_CC3000_VBAT,
SPI_CLOCK_DIVIDER);
#define WLAN_SSID ""
#define WLAN_PASS ""
#define WLAN_SECURITY WLAN_SEC_WPA2
#define IDLE_TIMEOUT_MS 3000
#define WEBSITE "192.168.10.100"
#define WEBPAGE "/DesignProject/pages/add.php"
#define SD_CS 4
#define SPI_CS 53
const int pirPin = 48;
uint32_t ip = 3232238180;
ArduCAM myCAM(OV2640,SPI_CS);
RTC_DS1307 rtc;
uint8_t temp;
uint8_t vid,pid;
#if defined (__AVR__)
Wire.begin();
#endif
#if defined(__arm__)
Wire1.begin();
#endif
Serial.println("Program Start!\n");
Serial.println(F("Initialization done!\n"));
//Initializing RTC
Serial.println(F("Initializating RTC!"));
if (!rtc.begin()){
Serial.println(F("Failed to Initialize RTC!\n"));
//rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
Serial.println(F("Initialization of RTC sucessful!\n"));
SPI.begin();
//ARDUCAM
Serial.println("ArduCAM Start!");
// set the SPI_CS as an output:
pinMode(SPI_CS, OUTPUT);
pinMode(ADAFRUIT_CC3000_CS, OUTPUT);
//Check if the ArduCAM SPI bus is OK
myCAM.write_reg(ARDUCHIP_TEST1, 0x55);
temp = myCAM.read_reg(ARDUCHIP_TEST1);
if(temp != 0x55)
Serial.println("SPI interface Error!\n");
while(1);
myCAM.write_reg(ARDUCHIP_MODE, 0x00);
//Check if the camera module type is OV2640
myCAM.rdSensorReg8_8(OV2640_CHIPID_HIGH, &vid);
myCAM.rdSensorReg8_8(OV2640_CHIPID_LOW, &pid);
if((vid != 0x26) || (pid != 0x42))
Serial.println("Can't find OV2640 module!\n");
Serial.println("OV2640 detected\n");
//Change to BMP capture mode and initialize the OV2640 module
myCAM.set_format(JPEG);
myCAM.InitCAM();
myCAM.OV2640_set_JPEG_size(OV2640_1600x1200);
//Initialization of SD Card
Serial.println(F("Initializing SD Card!"));
if (!SD.begin(SD_CS)) {
Serial.println(F("Initialization failed!\n"));
while(1);
char str[8];
File outFile;
byte buf[256];
unsigned long previous_time = 0;
static int i = 0;
static int n = 0;
static int k = 0;
uint8_t temp, temp_last;
int total_time = 0;
if(digitalRead(pirPin)==HIGH)
digitalWrite(SD_CS, HIGH);
//Flush the FIFO
myCAM.flush_fifo();
//Clear the capture done flag
myCAM.clear_fifo_flag();
//Start capture
myCAM.start_capture();
Serial.println("Start Capture");
while(!(myCAM.read_reg(ARDUCHIP_TRIG) & CAP_DONE_MASK));
Serial.println("Capture Done!");
//myCAM.CS_HIGH();
//Construct a file name
k = k + 1;
itoa(k, str, 10);
strcat(str,".jpg"); //Generate file name
//myCAM.write_reg(ARDUCHIP_MODE, 0x00); //Switch to MCU, freeze the screen
//GrabImage(str);
//Open the new file
outFile = SD.open(str, O_WRITE | O_CREAT | O_TRUNC);
if (! outFile)
Serial.println("Open file failed");
return;
Serial.println("Open file Successful");
total_time = millis();
i = 0;
myCAM.CS_LOW();
myCAM.set_fifo_burst();
temp = SPI.transfer(0x00);
//Read JPEG data from FIFO
while ( (temp != 0xD9) | (temp_last != 0xFF))
temp_last = temp;
//Write image data to buffer if not full
if (i < 256)
buf[i++] = temp;
//Write 256 bytes image data to file
myCAM.CS_HIGH();
outFile.write(buf, 256);
i = 0;
buf[i++] = temp;
myCAM.CS_LOW();
//Write the remain bytes in the buffer
if (i > 0)
myCAM.CS_HIGH();
outFile.write(buf, i);
//Close the file
outFile.close();
total_time = millis() - total_time;
Serial.print("Total time used:");
Serial.print(total_time, DEC);
Serial.println(" millisecond");
//Initializing CC3000(Wifi Shield)
Serial.println(F("Initializating Wifi Shield!"));
if (!cc3000.begin())
Serial.println(F("Couldn't begin()! Check your wiring?"));
while(1);
//connect to SSID; if err, display failed
Serial.println(F("Connecting..."));
if (!cc3000.connectToAP(WLAN_SSID, WLAN_PASS, WLAN_SECURITY)) {
Serial.println(F("Failed to Connect!"));
while(1);
//else display connected
Serial.println(F("Connected!"));
//request for DHCP to find IP address
//will be deleted after configuring router
//Don't leave until IP address, DNS, and gateway is assigned
Serial.println(F("Request DHCP"));
while (!cc3000.checkDHCP())
delay(100);
while (! displayConnectionDetails()) {
myCAM.CS_LOW();
digitalWrite(ADAFRUIT_CC3000_CS, HIGH);
bool displayConnectionDetails(void)
uint32_t ipAddress, netmask, gateway, dhcpserv, dnsserv;
if(!cc3000.getIPAddress(&ipAddress, &netmask, &gateway, &dhcpserv, &dnsserv))
Serial.println(F("Unable to retrieve the IP Address!\r\n"));
return false;
Serial.print(F("\nIP Addr: ")); cc3000.printIPdotsRev(ipAddress);
Serial.print(F("\nNetmask: ")); cc3000.printIPdotsRev(netmask);
Serial.print(F("\nGateway: ")); cc3000.printIPdotsRev(gateway);
Serial.print(F("\nDHCPsrv: ")); cc3000.printIPdotsRev(dhcpserv);
Serial.print(F("\nDNSserv: ")); cc3000.printIPdotsRev(dnsserv);
return true;
I have an Arduino Mega2560
CC3000 Wifi Shield (CC3000 WIFI Hardware Manual.pdf - Google Drive)
ArduCam mini OV2640
Arducam Connections
CS 53(Mega)
SCL SCL(Mega)
SDA SDA(Mega)
5v 5v(Wifi Shield)
GND GND(Wifi Shield)
MOSI, MISO, SCK (Connected to external ICSP Headers above the Wifi Shield as shown on the link above for the Wifi Shield)
This is the output on the Serial Monitor Below and stops at the connection details
Program Start!
ArduCAM Start!
OV2640 detected
Start Capture
Capture Done!
Total time used:4088 millisecond
Connecting...
Connected!
Request DHCP
IP Addr: 192.168.10.101
Netmask: 255.255.255.0
Gateway: 192.168.10.254
DHCPsrv: 0.0.0.0
DNSserv: 192.168.10.198
