Missing port
Hello
I bought an Arduino UNO Rev3 a couple of days ago.
I started coding some sketches and tried to upload them. I needed three attempts to get the mac (Yosemite) auto adding a modem device and get the IDE software uploading the sketches.
Everithing worked fine until yesterday. Uploading a sketch I got this error:
avrdude: ser_open(): can't open device "/dev/cu.usbmodem1411": No such file or directory
I've tried to connect to it from an old macbook with no success.
Also tried to reflash the firmware to the ATMEGA16u2 but I can't connect to it. I can't see the Arduino at the system report USB.
The green ON LED is lighting. The 'L' LED blinks once when I plug the board to the mac.
I've tried to wire again the las project I was working on and IT WORKS!
What can I do?
Thank you in advance.
same here :frowning:
plizz help
I have the exact same problem, I have installed and reinstalled drivers and it still doesn't work for my Arduino mega 2560.
also i've that problem.
maybe you need to check your directory "/dev/cu.usbmodem1411" is where connected the USB port
or try to connect the Arduino as another USB port in you computer.
then mine's worked:)
I had this issue and resolved it by trying a different USB port on my Macbook Pro
i have this same problem and already switched usb ports on my MacBook pro
I had the same message appear with a new Arduino Nano. To solve it, I had to go to
Tools -> Port-> /dev/cu.usbserial-A9UXT7VZ
I hope this helps someone.
Thanks for the last post. It helped me solve my problem. Until today I had been using my Arduino board with no problems. Today I tried to upload the "Blink" program and I got this error message:
avr_dude: ser_open(): can't open device "dev/cu.usbmodem14111": No such file or directory.
I do not know why this started happening today. Maybe it is because I had been experimenting with an Arduino Bluetooth board and something changed. I opened a terminal on my MacBook and typed ...
ls -l /dev/cu.*
... and I got this response:
/dev/cu.Bluetooth-Incoming-Port
/dev/cu.SSDL
/dev/cu.usbmodem141101
So I saw I had the file /dev/cu.usbmodem141101 on my Mac, not /dev/cu.usbmodem14111. After reading the post above I opened Arduino's Tools->Port and found /dev/cu.usbmodem141101 was present in a list of ports there but it was not selected. I selected it and my "Blink" download problem went away.
Thanks!
