Missing SPI Library
Several questions -
  1. Trying to compile and error on finding SPI.h. I try both "SPI.h" and <SPI.h> in the include,
    no luck. Web tells me to import library, but I see no menu item labeled import ?
  2. So I try to add library, search in lib manager for SPI, and find all kinds of libs
    with SPI in the name but not named just SPI ? So then I search just Arduino filter,
    find jillions of libraries that dont seem to have any connection to SPI.
  3. Go to library ref doc, find SPI, no where on the doc is the name of the library
    to find in the lib manager. Or install instructions.
  4. Search web for Arduino SPI zip library, no luck, but there is a menu item to add a zip lib in the
    sketch menu.......OK mental disease is hard to self diagnose
    Dana.....
  5. Browse in file manager and find the lib, its there.....in IDE folder. Huh.
  6. Is it just me or should I jump off the proverbial cliff with the rest of the Lemmings :slight_smile: ?
Regards, Dana.
I'm going to ask you to post some additional information that might help us to identify the problem.
Please do this:
  1. If you don't still have the IDE or web editor open with the error present, repeat the process that generated it.
  2. You now need to copy the full and exact text of the output.
    The procedure for doing this is different depending on which Arduino development software you are using:
    • Arduino IDE 1.x: Click the Copy error messages button on the right side of the orange bar in the IDE.
    • Arduino IDE 2.x: Right click on the black "Output" pane at the bottom of the IDE window and then select Copy All from the context menu.
    • Arduino Web Editor: Click the icon that looks like two pieces of paper at the top right corner of the black console window Web Editor.
  3. Open a forum reply here by clicking the Reply button.
  4. Click the </> icon on the post composer toolbar.
    This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
    Code block
  5. Press Ctrl+V.
    This will paste the compilation output into the code block.
  6. Move the cursor outside of the code block markup before you add any additional text to your reply.
  7. Click the Reply button to post the output.
This is because the SPI library is a "platform bundled library". This means it comes pre-installed with each Arduino boards platform. So under the hood you use Boards Manager rather than Library Manager to install the SPI library.
The SPI library API is standardized, but the implementation code is very architecture-specific. For this reason, there is no universal SPI library you could install standalone. Instead, what happens is each boards platform author creates their own version of the SPI library and bundles it with the boards platform. The Arduino IDE automatically uses the SPI library from the platform of the currently selected board.
Here are some examples of different versions of the SPI library:
This would install the SPI library globally, where it would be available to any board you compiled for. But as I said there is no universal SPI library, so you might end up using it for a board it is not compatible with, which would cause some very confusing issues. For this reason, you should never install any platform bundled library globally via "Add .ZIP Library" or manually unless you have a very specific reason for doing so (e.g., you are doing development work on the library).
Keep in mind that you may have multiple versions of the SPI library on your computer and the one you find is not necessarily the one your board is using. Studying or modifying the wrong library can result in some very confusing times!
Thank you for reply, grateful.
Board is UNO, OS is Win 10, did a re-install of IDE. Added to
environment path variable to make sure it could be found....
Arduino: 1.8.19 (Windows 10), Board: "Arduino Uno"
ArduinoISP:162:10: fatal error: Please import the SPI library from the Sketch > Import Library menu.
As of Arduino 0019, the Ethernet library depends on the SPI library.
You appear to be using it or another library that depends on the SPI library.
 #include "SPI.h"
compilation terminated.
exit status 1
option enabled in File -> Preferences.
The code -
// ArduinoISP
// Copyright (c) 2008-2011 Randall Bohn
// If you require a license, see
// https://opensource.org/licenses/bsd-license.php
// This sketch turns the Arduino into a AVRISP using the following Arduino pins:
// Pin 10 is used to reset the target microcontroller.
// By default, the hardware SPI pins MISO, MOSI and SCK are used to communicate
// with the target. On all Arduinos, these pins can be found
// on the ICSP/SPI header:
//               MISO °. . 5V (!) Avoid this pin on Due, Zero...
//               SCK   . . MOSI
//                     . . GND
// On some Arduinos (Uno,...), pins MOSI, MISO and SCK are the same pins as
// digital pin 11, 12 and 13, respectively. That is why many tutorials instruct
// you to hook up the target to these pins. If you find this wiring more
// practical, have a define USE_OLD_STYLE_WIRING. This will work even when not
// using an Uno. (On an Uno this is not needed).
// Alternatively you can use any other digital pin by configuring
// software ('BitBanged') SPI and having appropriate defines for PIN_MOSI,
// PIN_MISO and PIN_SCK.
// IMPORTANT: When using an Arduino that is not 5V tolerant (Due, Zero, ...) as
// the programmer, make sure to not expose any of the programmer's pins to 5V.
// A simple way to accomplish this is to power the complete system (programmer
// and target) at 3V3.
// Put an LED (with resistor) on the following pins:
// 9: Heartbeat   - shows the programmer is running
// 8: Error       - Lights up if something goes wrong (use red if that makes sense)
// 7: Programming - In communication with the slave
#include "Arduino.h"
#undef SERIAL
#define PROG_FLICKER true
// Configure SPI clock (in Hz).
// E.g. for an ATtiny @ 128 kHz: the datasheet states that both the high and low
// SPI clock pulse must be > 2 CPU cycles, so take 3 cycles i.e. divide target
// f_cpu by 6:
//     #define SPI_CLOCK            (128000/6)
// A clock slow enough for an ATtiny85 @ 1 MHz, is a reasonable default:
#define SPI_CLOCK 		(1000000/6)
// Select hardware or software SPI, depending on SPI clock.
// Currently only for AVR, for other architectures (Due, Zero,...), hardware SPI
// is probably too fast anyway.
#if defined(ARDUINO_ARCH_AVR)
  #if SPI_CLOCK > (F_CPU / 128)
    #define USE_HARDWARE_SPI
  #endif
#endif
// Configure which pins to use:
// The standard pin configuration.
#ifndef ARDUINO_HOODLOADER2
  #define RESET     10 // Use pin 10 to reset the target rather than SS
  #define LED_HB    9
  #define LED_ERR   8
  #define LED_PMODE 7
  // Uncomment following line to use the old Uno style wiring
  // (using pin 11, 12 and 13 instead of the SPI header) on Leonardo, Due...
  // #define USE_OLD_STYLE_WIRING
  #ifdef USE_OLD_STYLE_WIRING
    #define PIN_MOSI	11
    #define PIN_MISO	12
    #define PIN_SCK		13
  #endif
  // HOODLOADER2 means running sketches on the ATmega16U2 serial converter chips
  // on Uno or Mega boards. We must use pins that are broken out:
#else
  #define RESET     	4
  #define LED_HB    	7
  #define LED_ERR   	6
  #define LED_PMODE 	5
#endif
// By default, use hardware SPI pins:
#ifndef PIN_MOSI
  #define PIN_MOSI 	MOSI
#endif
#ifndef PIN_MISO
  #define PIN_MISO 	MISO
#endif
#ifndef PIN_SCK
  #define PIN_SCK 	SCK
#endif
// Force bitbanged SPI if not using the hardware SPI pins:
#if (PIN_MISO != MISO) ||  (PIN_MOSI != MOSI) || (PIN_SCK != SCK)
  #undef USE_HARDWARE_SPI
#endif
// Configure the serial port to use.
// Prefer the USB virtual serial port (aka. native USB port), if the Arduino has one:
//   - it does not autoreset (except for the magic baud rate of 1200).
//   - it is more reliable because of USB handshaking.
// Leonardo and similar have an USB virtual serial port: 'Serial'.
// Due and Zero have an USB virtual serial port: 'SerialUSB'.
// On the Due and Zero, 'Serial' can be used too, provided you disable autoreset.
// To use 'Serial': #define SERIAL Serial
#ifdef SERIAL_PORT_USBVIRTUAL
  #define SERIAL SERIAL_PORT_USBVIRTUAL
#else
#endif
// Configure the baud rate:
#define BAUDRATE	19200
// #define BAUDRATE	115200
// #define BAUDRATE	1000000
#define HWVER 2
#define SWMAJ 1
#define SWMIN 18
// STK Definitions
#define STK_OK      0x10
#define STK_FAILED  0x11
#define STK_UNKNOWN 0x12
#define STK_INSYNC  0x14
#define STK_NOSYNC  0x15
#define CRC_EOP     0x20 //ok it is a space...
void pulse(int pin, int times);
#ifdef USE_HARDWARE_SPI
#include "SPI.h"
#else
#define SPI_MODE0 0x00
#if !defined(ARDUINO_API_VERSION) || ARDUINO_API_VERSION != 10001 // A SPISettings class is declared by ArduinoCore-API 1.0.1
class SPISettings {
  public:
    // clock is in Hz
    SPISettings(uint32_t clock, uint8_t bitOrder, uint8_t dataMode) : clockFreq(clock) {
      (void) bitOrder;
      (void) dataMode;
    uint32_t getClockFreq() const {
      return clockFreq;
  private:
    uint32_t clockFreq;
#endif  // !defined(ARDUINO_API_VERSION)
class BitBangedSPI {
  public:
    void begin() {
      digitalWrite(PIN_SCK, LOW);
      digitalWrite(PIN_MOSI, LOW);
      pinMode(PIN_SCK, OUTPUT);
      pinMode(PIN_MOSI, OUTPUT);
      pinMode(PIN_MISO, INPUT);
    void beginTransaction(SPISettings settings) {
      pulseWidth = (500000 + settings.getClockFreq() - 1) / settings.getClockFreq();
      if (pulseWidth == 0) {
        pulseWidth = 1;
    void end() {}
    uint8_t transfer(uint8_t b) {
      for (unsigned int i = 0; i < 8; ++i) {
        digitalWrite(PIN_MOSI, (b & 0x80) ? HIGH : LOW);
        digitalWrite(PIN_SCK, HIGH);
        delayMicroseconds(pulseWidth);
        b = (b << 1) | digitalRead(PIN_MISO);
        digitalWrite(PIN_SCK, LOW); // slow pulse
      return b;
  private:
    unsigned long pulseWidth; // in microseconds
static BitBangedSPI SPI;
#endif
  SERIAL.begin(BAUDRATE);
  pinMode(LED_PMODE, OUTPUT);
  pulse(LED_PMODE, 2);
  pinMode(LED_ERR, OUTPUT);
  pulse(LED_ERR, 2);
  pinMode(LED_HB, OUTPUT);
  pulse(LED_HB, 2);
int ISPError = 0;
int pmode = 0;
// address for reading and writing, set by 'U' command
unsigned int here;
uint8_t buff[256]; // global block storage
#define beget16(addr) (*addr * 256 + *(addr+1) )
typedef struct param {
  uint8_t devicecode;
  uint8_t revision;
  uint8_t progtype;
  uint8_t parmode;
  uint8_t polling;
  uint8_t selftimed;
  uint8_t lockbytes;
  uint8_t fusebytes;
  uint8_t flashpoll;
  uint16_t eeprompoll;
  uint16_t pagesize;
  uint16_t eepromsize;
  uint32_t flashsize;
parameter;
parameter param;
// this provides a heartbeat on pin 9, so you can tell the software is running.
uint8_t hbval = 128;
int8_t hbdelta = 8;
void heartbeat() {
  static unsigned long last_time = 0;
  unsigned long now = millis();
  if ((now - last_time) < 40) {
    return;
  last_time = now;
  if (hbval > 192) {
    hbdelta = -hbdelta;
  if (hbval < 32) {
    hbdelta = -hbdelta;
  hbval += hbdelta;
  analogWrite(LED_HB, hbval);
static bool rst_active_high;
void reset_target(bool reset) {
  digitalWrite(RESET, ((reset && rst_active_high) || (!reset && !rst_active_high)) ? HIGH : LOW);
void loop(void) {
  // is pmode active?
  if (pmode) {
    digitalWrite(LED_PMODE, HIGH);
    digitalWrite(LED_PMODE, LOW);
  // is there an error?
  if (ISPError) {
    digitalWrite(LED_ERR, HIGH);
    digitalWrite(LED_ERR, LOW);
  // light the heartbeat LED
  heartbeat();
  if (SERIAL.available()) {
    avrisp();
uint8_t getch() {
  while (!SERIAL.available());
  return SERIAL.read();
void fill(int n) {
  for (int x = 0; x < n; x++) {
    buff[x] = getch();
#define PTIME 30
void pulse(int pin, int times) {
  do {
    digitalWrite(pin, HIGH);
    delay(PTIME);
    digitalWrite(pin, LOW);
    delay(PTIME);
  } while (times--);
void prog_lamp(int state) {
  if (PROG_FLICKER) {
    digitalWrite(LED_PMODE, state);
uint8_t spi_transaction(uint8_t a, uint8_t b, uint8_t c, uint8_t d) {
  SPI.transfer(a);
  SPI.transfer(b);
  SPI.transfer(c);
  return SPI.transfer(d);
void empty_reply() {
  if (CRC_EOP == getch()) {
    SERIAL.print((char)STK_INSYNC);
    SERIAL.print((char)STK_OK);
    ISPError++;
    SERIAL.print((char)STK_NOSYNC);
void breply(uint8_t b) {
    SERIAL.print((char)b);
    ISPError++;
void get_version(uint8_t c) {
  switch (c) {
    case 0x80:
      breply(HWVER);
    case 0x81:
      breply(SWMAJ);
    case 0x82:
      breply(SWMIN);
    case 0x93:
      breply('S'); // serial programmer
    default:
      breply(0);
void set_parameters() {
  // call this after reading parameter packet into buff[]
  param.devicecode = buff[0];
  param.revision   = buff[1];
  param.progtype   = buff[2];
  param.parmode    = buff[3];
  param.polling    = buff[4];
  param.selftimed  = buff[5];
  param.lockbytes  = buff[6];
  param.fusebytes  = buff[7];
  param.flashpoll  = buff[8];
  // ignore buff[9] (= buff[8])
  // following are 16 bits (big endian)
  param.eeprompoll = beget16(&buff[10]);
  param.pagesize   = beget16(&buff[12]);
  param.eepromsize = beget16(&buff[14]);
  // 32 bits flashsize (big endian)
  param.flashsize = buff[16] * 0x01000000
                    + buff[17] * 0x00010000
                    + buff[18] * 0x00000100
                    + buff[19];
  // AVR devices have active low reset, AT89Sx are active high
  rst_active_high = (param.devicecode >= 0xe0);
void start_pmode() {
  // Reset target before driving PIN_SCK or PIN_MOSI
  // SPI.begin() will configure SS as output, so SPI master mode is selected.
  // We have defined RESET as pin 10, which for many Arduinos is not the SS pin.
  // So we have to configure RESET as output here,
  // (reset_target() first sets the correct level)
  reset_target(true);
  pinMode(RESET, OUTPUT);
  SPI.begin();
  SPI.beginTransaction(SPISettings(SPI_CLOCK, MSBFIRST, SPI_MODE0));
  // See AVR datasheets, chapter "SERIAL_PRG Programming Algorithm":
  // Pulse RESET after PIN_SCK is low:
  delay(20); // discharge PIN_SCK, value arbitrarily chosen
  reset_target(false);
  // Pulse must be minimum 2 target CPU clock cycles so 100 usec is ok for CPU
  // speeds above 20 KHz
  delayMicroseconds(100);
  reset_target(true);
  // Send the enable programming command:
  delay(50); // datasheet: must be > 20 msec
  spi_transaction(0xAC, 0x53, 0x00, 0x00);
  pmode = 1;
void end_pmode() {
  SPI.end();
  // We're about to take the target out of reset so configure SPI pins as input
  pinMode(PIN_MOSI, INPUT);
  pinMode(PIN_SCK, INPUT);
  pinMode(RESET, INPUT);
  pmode = 0;
void universal() {
  uint8_t ch;
  fill(4);
  ch = spi_transaction(buff[0], buff[1], buff[2], buff[3]);
  breply(ch);
void flash(uint8_t hilo, unsigned int addr, uint8_t data) {
  spi_transaction(0x40 + 8 * hilo,
                  addr >> 8 & 0xFF,
                  addr & 0xFF,
                  data);
void commit(unsigned int addr) {
  if (PROG_FLICKER) {
    prog_lamp(LOW);
  spi_transaction(0x4C, (addr >> 8) & 0xFF, addr & 0xFF, 0);
  if (PROG_FLICKER) {
    delay(PTIME);
    prog_lamp(HIGH);
unsigned int current_page() {
  if (param.pagesize == 32) {
    return here & 0xFFFFFFF0;
  if (param.pagesize == 64) {
    return here & 0xFFFFFFE0;
  if (param.pagesize == 128) {
    return here & 0xFFFFFFC0;
  if (param.pagesize == 256) {
    return here & 0xFFFFFF80;
  return here;
void write_flash(int length) {
  fill(length);
    SERIAL.print((char) STK_INSYNC);
    SERIAL.print((char) write_flash_pages(length));
    ISPError++;
    SERIAL.print((char) STK_NOSYNC);
uint8_t write_flash_pages(int length) {
  int x = 0;
  unsigned int page = current_page();
  while (x < length) {
    if (page != current_page()) {
      commit(page);
    flash(LOW, here, buff[x++]);
    flash(HIGH, here, buff[x++]);
    here++;
  commit(page);
  return STK_OK;
#define EECHUNK (32)
uint8_t write_eeprom(unsigned int length) {
  // here is a word address, get the byte address
  unsigned int start = here * 2;
  unsigned int remaining = length;
  if (length > param.eepromsize) {
    ISPError++;
    return STK_FAILED;
  while (remaining > EECHUNK) {
    write_eeprom_chunk(start, EECHUNK);
    start += EECHUNK;
    remaining -= EECHUNK;
  write_eeprom_chunk(start, remaining);
  return STK_OK;
// write (length) bytes, (start) is a byte address
uint8_t write_eeprom_chunk(unsigned int start, unsigned int length) {
  // this writes byte-by-byte, page writing may be faster (4 bytes at a time)
  fill(length);
  prog_lamp(LOW);
  for (unsigned int x = 0; x < length; x++) {
    unsigned int addr = start + x;
    spi_transaction(0xC0, (addr >> 8) & 0xFF, addr & 0xFF, buff[x]);
    delay(45);
  prog_lamp(HIGH);
  return STK_OK;
void program_page() {
  char result = (char) STK_FAILED;
  unsigned int length = 256 * getch();
  length += getch();
  char memtype = getch();
  // flash memory @here, (length) bytes
  if (memtype == 'F') {
    write_flash(length);
    return;
  if (memtype == 'E') {
    result = (char)write_eeprom(length);
      SERIAL.print(result);
      ISPError++;
    return;
  SERIAL.print((char)STK_FAILED);
  return;
uint8_t flash_read(uint8_t hilo, unsigned int addr) {
  return spi_transaction(0x20 + hilo * 8,
                         (addr >> 8) & 0xFF,
                         addr & 0xFF,
                         0);
char flash_read_page(int length) {
  for (int x = 0; x < length; x += 2) {
    uint8_t low = flash_read(LOW, here);
    SERIAL.print((char) low);
    uint8_t high = flash_read(HIGH, here);
    SERIAL.print((char) high);
    here++;
  return STK_OK;
char eeprom_read_page(int length) {
  // here again we have a word address
  for (int x = 0; x < length; x++) {
    uint8_t ee = spi_transaction(0xA0, (addr >> 8) & 0xFF, addr & 0xFF, 0xFF);
    SERIAL.print((char) ee);
  return STK_OK;
void read_page() {
  char result = (char)STK_FAILED;
  length += getch();
  if (CRC_EOP != getch()) {
    ISPError++;
    return;
    result = flash_read_page(length);
    result = eeprom_read_page(length);
void read_signature() {
    ISPError++;
    return;
  uint8_t high = spi_transaction(0x30, 0x00, 0x00, 0x00);
  uint8_t middle = spi_transaction(0x30, 0x00, 0x01, 0x00);
  SERIAL.print((char) middle);
  uint8_t low = spi_transaction(0x30, 0x00, 0x02, 0x00);
  SERIAL.print((char) STK_OK);
void avrisp() {
  uint8_t ch = getch();
  switch (ch) {
    case '0': // signon
      ISPError = 0;
      empty_reply();
    case '1':
      if (getch() == CRC_EOP) {
        SERIAL.print("AVR ISP");
        ISPError++;
    case 'A':
      get_version(getch());
    case 'B':
      fill(20);
      set_parameters();
      empty_reply();
    case 'E': // extended parameters - ignore for now
      fill(5);
      empty_reply();
    case 'P':
      if (!pmode) {
        start_pmode();
      empty_reply();
    case 'U': // set address (word)
      here = getch();
      here += 256 * getch();
      empty_reply();
    case 0x60: //STK_PROG_FLASH
      getch(); // low addr
      getch(); // high addr
      empty_reply();
    case 0x61: //STK_PROG_DATA
      getch(); // data
      empty_reply();
    case 0x64: //STK_PROG_PAGE
      program_page();
    case 0x74: //STK_READ_PAGE 't'
      read_page();
    case 'V': //0x56
      universal();
    case 'Q': //0x51
      ISPError = 0;
      end_pmode();
      empty_reply();
    case 0x75: //STK_READ_SIGN 'u'
      read_signature();
    // expecting a command, not CRC_EOP
    // this is how we can get back in sync
    case CRC_EOP:
      ISPError++;
    // anything else we will return STK_UNKNOWN
    default:
      ISPError++;
        SERIAL.print((char)STK_UNKNOWN);
That is definitely strange. I just gave it a try and the sketch compiles just fine for me with Arduino Uno board selected in Arduino IDE 1.8.19.
I'm going to ask you to provide the verbose compilation output, which might allow us to determine the cause of the problem or a workaround.
Please do this:
  1. Select File > Preferences from the Arduino IDE's menus.
  2. Check the box next to "Show verbose output during: [] compilation".
  3. Click the OK button.
  4. Select Sketch > Verify/Compile from the Arduino IDE's menus.
  5. After the compilation fails you'll see a button on the right side of the orange bar in the Arduino IDE: Copy error messages. Click that button.
    This copies the full output to the clipboard.
  6. Open a forum reply here by clicking the Reply button.
  7. Click the </> icon on the post composer toolbar.
    Code block
  8. Press Ctrl+V.
  9. Move the cursor outside of the code tags before you add any additional text to your reply.
  10. Click the Reply button to post the output.
About this:
This is a very old message from the Arduino IDE. It has not been necessary to do this since Arduino IDE 1.6.5.
As for "the Sketch > Import Library menu". That menu item was renamed to Sketch > Include Library many years ago. But don't be misled, that will not solve the issue.
Verbose output of Compile. 1.8.19 Arduino IDE
Attached is Arduino IDE sketch for Arduino as ISP,
no mods from the standard sketch supplied in IDE.
Interesting, on another PC, 1.8.15 ArduinoISP sketch compiled just fine.
Same sketch as I have been posting problems above.
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\danaa\AppData\Local\Arduino15\packages -hardware C:\Users\danaa\Documents\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\danaa\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\danaa\Documents\Arduino\libraries -fqbn=arduino:avr:uno -ide-version=10819 -build-path C:\Users\danaa\AppData\Local\Temp\arduino_build_311605 -warnings=none -build-cache C:\Users\danaa\AppData\Local\Temp\arduino_cache_237781 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Users\danaa\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\danaa\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avrdude.path=C:\Users\danaa\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\danaa\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.arduinoOTA.path=C:\Users\danaa\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\danaa\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -verbose C:\Program Files (x86)\Arduino\examples\11.ArduinoISP\ArduinoISP\ArduinoISP.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\danaa\AppData\Local\Arduino15\packages -hardware C:\Users\danaa\Documents\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\danaa\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\danaa\Documents\Arduino\libraries -fqbn=arduino:avr:uno -ide-version=10819 -build-path C:\Users\danaa\AppData\Local\Temp\arduino_build_311605 -warnings=none -build-cache C:\Users\danaa\AppData\Local\Temp\arduino_cache_237781 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Users\danaa\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\danaa\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avrdude.path=C:\Users\danaa\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\danaa\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.arduinoOTA.path=C:\Users\danaa\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\danaa\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -verbose C:\Program Files (x86)\Arduino\examples\11.ArduinoISP\ArduinoISP\ArduinoISP.ino
Using board 'uno' from platform in folder: C:\Users\danaa\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.4
Using core 'arduino' from platform in folder: C:\Users\danaa\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.4
Detecting libraries used...
"C:\\Users\\danaa\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\danaa\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.4\\cores\\arduino" "-IC:\\Users\\danaa\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.4\\variants\\standard" "C:\\Users\\danaa\\AppData\\Local\\Temp\\arduino_build_311605\\sketch\\ArduinoISP.ino.cpp" -o nul
Alternatives for SPI.h: []
ResolveLibrary(SPI.h)
  -> candidates: []
 #include "SPI.h"
exit status 1
ArduinoISP.ino (17.7 KB)
