missing terminating " character Error message Please help
I am working with my arduino uno with and lcd screen hooked up to it and I am getting a strange error on line 27 I’m not sure what it means and the code is basically the same as the other lines but it keeps saying “missing terminating " character”
This is the error message that i copied:
Arduino: 1.8.5 (Windows 10), Board: “Arduino/Genuino Uno”
C:\Users\laris\Desktop\Adyo_s_special_Software\Adyo_s_special_Software.ino:27:299: warning: missing terminating " character
case 0xFFA857: lcd.setCursor(15,1);lcd.print("<"); break; "); lcd.setCursor(0,0); break;
Adyo_s_special_Software:27: error: missing terminating " character
Multiple libraries were found for “LiquidCrystal.h”
Used: C:\Users\laris\OneDrive\Documents\Arduino\libraries\LiquidCrystal
Not used: C:\Program Files (x86)\Arduino\libraries\LiquidCrystal
exit status 1
And this is the code:
#include <IRremote.h>
#include <LiquidCrystal.h>
int receiver = 6; // Signal Pin of IR receiver to Arduino Digital Pin 11
/*-----( Declare objects )-----*/
LiquidCrystal lcd(7, 8, 9, 10, 11, 12);
IRrecv irrecv(receiver);     // create instance of 'irrecv'
decode_results results;      // create instance of 'decode_results'
/*-----( Function )-----*/
void translateIR() // takes action based on IR code received
// describing Remote IR codes
  switch(results.value)
  case 0xFF629D: lcd.print("Vol+"); break;
  case 0xFF22DD: lcd.print("FAST BACK");    break;
  case 0xFF02FD: lcd.print("PAUSE");    break;
  case 0xFFC23D: lcd.print("FAST FORWARD");   break;
  case 0xFF9867: lcd.print("2");    break;
  case 0xFFB04F: lcd.print("3");   break;
  case 0xFF6897: lcd.print("1");    break;
  case 0xFF30CF: lcd.print("4");    break;
  case 0xFF18E7: lcd.print("5");    break;
  case 0xFF7A85: lcd.print("6");    break;
  case 0xFF10EF: lcd.print("7");    break;
  case 0xFF38C7: lcd.print("8");    break;
  case 0xFF5AA5: lcd.print("9");    break;
//  case 0xFF42BD: lcd.print("7");    break;
  case 0xFF4AB5: lcd.print("0");    break;
  //case 0xFF52AD: lcd.print("9");    break;
  default:
    Serial.println(" other button   ");
  }// End Case
  delay(500); // Do not get immediate repeat
} //END translateIR
void setup()   /*----( SETUP: RUNS ONCE )----*/
  Serial.println("IR Receiver Button Decode");
  irrecv.enableIRIn(); // Start the receiver
  lcd.begin(16, 2);
  lcd.setCursor(0,0);
  lcd.print("Room Lights:   <");
  lcd.setCursor(0,1);
  lcd.print("Door:");
}/*--(end setup )---*/
void loop()   /*----( LOOP: RUNS CONSTANTLY )----*/
  if (irrecv.decode(&results)) // have we received an IR signal?
    translateIR();
    irrecv.resume(); // receive the next value
}/* --(end main loop )-- */
case 0xFFA857: Check the extreme right end of that line
oh...
There is obviously something missing between break; and the next quote in this piece of code
I have removed a lot of space characters to make it more obvious.
...R
