Mistake in Reference manual
I think there is a mistake in the reference manual describing the compound |=. It reads:
Consequently - to set bits 0 & 1 of a variable, while leaving the rest of the variable unchanged, use the compound bitwise AND operator (&=) with the constant B00000011
1 0 1 0 1 0 1 0 variable
0 0 0 0 0 0 1 1 mask
1 0 1 0 1 0 1 1
variable unchanged
bits set
This shoud be the compound bitwise OR. Or not?
It is a bit misleading the OR operation allows you to set bits with out affecting other bits while the AND operation allows you to clear bits without affecting anything else.
For the OR a 0 in the mask leaves the bit alone
a 1 in the mask sets a bit.
For and AND operation a 1 in the mask leaves the bit alone
a 0 in the mask clears a bit.
From the Arduino reference section may help?
"Warning
Make sure you don't mistake the boolean AND operator, && (double ampersand) for the bitwise AND operator & (single ampersand). They are entirely different beasts.
Similarly, do not confuse the boolean || (double pipe) operator with the bitwise OR operator | (single pipe).
The bitwise not ~ (tilde) looks much different than the boolean not ! (exclamation point or "bang" as the programmers say) but you still have to be sure which one you want where. The example you posted is showing a bitwise OR operator."
A boolean operator ends up with just a true or false result, a bitwise operator ends but changing or not changing bits in the variable depending on the mask value and operator used.
Lefty
I think the important word in the original post is the word AND.
   1  0  1  0  1  0  1  1
How is the lsb ANDed to 1?
Or am I barking up the wrong tree.
Edit: And the orher bits :slight_smile:
I agree with jabber. The text
should read
use the compound bitwise OR operator (|=)
The page in error is Arduino - Home, right? It looks to me like the section on compound bitwise OR may have been copied from the compound bitwise AND section, and not all text was updated.
And you are not barking up the wrong tree. :slight_smile:
Good catch, speakerf00d.
I think speakerf00d is 100% correct.
This:
should be changed to this:
Consequently - to set bits 0 & 1 of a variable, while leaving the rest of the variable unchanged, use the compound bitwise OR operator (|=) with the constant B00000011
