Mix code for me? Firmata Digital pins + BlinkMCom
Hi I was wondering could some one mix the digital pin section of the firmata arduino code with the BlinkMcommunicator Arduino code, so as that I can get my digital pins working in max msp along side the serial i2c function that the BlinkMcommunicator allows.
The BlinkMCommunicator code is
  • BlinkMCommunicator – Communication gateway between a computer and a BlinkM
  • Essentially turns an Arduino to an I2C<->serial adapter
  • Command format is:
  • pos description
  • 0
  • 1 <i2c_addr>
  • 2 <num_bytes_to_send>
  • 3 <num_bytes_to_receive>
  • 4 <send_byte0>
  • 5…n [<send_byte1>…]
  • Thus minimum command length is 5 bytes long, for reading back a color, e.g.:
  • {0x01,0x09,0x01,0x01, ‘g’}
  • Most commands will be 8 bytes long, say to fade to an RGB color, e.g.:
  • {0x01,0x09,0x04,0x00, ‘f’,0xff,0xcc,0x33}
  • The longest command is to write a script line, at 12 bytes long, e.g.:
  • {0x01,0x09,0x08,0x00, ‘W’,0x00,0x01,50,‘f’,0xff,0xcc,0x33}
  • BlinkM connections to Arduino
  • PWR - – gnd – black – Gnd
  • PWR + – +5V – red – 5V
  • I2C d – SDA – green – Analog In 4
  • I2C c – SCK – blue – Analog In 5
  • Note: This sketch resets the I2C address of the BlinkM.
  • If you don’t want this behavior, comment out “BlinkM_setAddress()”
  • in setup() and change the variable “blink_addr” to your BlinkM’s addr.
  • 2007-8, Tod E. Kurt, ThingM, http://thingm.com/
#include “Wire.h”
#include “BlinkM_funcs.h”
//#define DEBUG 1
// define this if you’re plugging a BlinkM directly into an Arduino,
// into the standard position on analog in pins 2-5
// otherwise you can comment it out.
#define BLINKM_ARDUINO_POWERED 1
#define CMD_START_BYTE 0x01
int blinkm_addr = 0x09;
byte serInStr[32]; // array that will hold the serial input string
int ledPin = 13;
pinMode(ledPin, OUTPUT);
if( BLINKM_ARDUINO_POWERED ) {
BlinkM_beginWithPower();
BlinkM_begin();
// FIXME:
//BlinkM_setAddress( blinkm_addr ); // comment out to not set address
Serial.begin(19200);
byte rc = BlinkM_checkAddress( blinkm_addr );
if( rc == -1 )
Serial.println(“no response”);
else if( rc == 1 )
Serial.println(“addr mismatch”);
Serial.println(“BlinkMCommander ready”);
#ifdef DEBUG
Serial.println(“DEBUG MODE”);
#endif
int num;
//read the serial port and create a string out of what you read
num = readCommand(serInStr);
if( num == 0 ) // see if we got a proper command string yet
return;
digitalWrite(ledPin,HIGH); // say we’re working on it
byte addr = serInStr[1];
byte sendlen = serInStr[2];
byte recvlen = serInStr[3];
byte* cmd = serInStr+4;
#ifdef DEBUG
Serial.print(" addr:"); Serial.print(addr,HEX);
Serial.print(" sendlen:"); Serial.print(sendlen,HEX);
Serial.print(" recvlen:"); Serial.print(recvlen,HEX);
Serial.print(" cmd[0…7]:"); Serial.print(cmd[0],HEX);
Serial.print(","); Serial.print(cmd[1],HEX);
Serial.print(","); Serial.print(cmd[2],HEX);
Serial.print(","); Serial.print(cmd[3],HEX);
Serial.print(","); Serial.print(cmd[4],HEX);
Serial.print(","); Serial.print(cmd[5],HEX);
Serial.print(","); Serial.print(cmd[6],HEX);
Serial.print(","); Serial.println(cmd[7],HEX);
#endif
BlinkM_sendCmd(addr, cmd, sendlen);
// if looking for a response, get it
if( recvlen!=0 ) {
byte resp[16];
int rc = BlinkM_receiveBytes(addr, resp, recvlen);
for( int i=0; i<recvlen; i++)
Serial.print(resp*,BYTE);*
  • for(int i=0; i<30;i++)*
    _ serInStr = 0; // say we’ve used the string (not needed really)_
* digitalWrite(ledPin,LOW); // show we’re done*
//read a string from the serial and store it in an array
//you must supply the str array variable
//returns number of bytes read, or zero if fail
uint8_t readCommand(byte str)
_
{_
uint8_t b,i;
_
if( ! Serial.available() ) return 0; // wait for serial*_
* b = Serial.read();*
* if( b != CMD_START_BYTE ) // check to see we’re at the start*
* return 0;*
#ifdef DEBUG
* Serial.println(“startbyte”);*
#endif
* str[0] = b;*
* i = 100;*
* while( Serial.available() < 3 ) { // wait for the rest*
* delay(1);*
* if( i-- == 0 ) return 0; // get out if takes too long*
* for( i=1; i<4; i++)*
_ str = Serial.read(); // fill it up
#ifdef DEBUG
* Serial.println(“header”);
#endif*
* uint8_t sendlen = str[2];*
#ifdef DEBUG
* Serial.print(“cmdlen:”); Serial.println( sendlen, DEC);
#endif*
* if( sendlen == 0 ) return 0;
i = 100;
while( Serial.available() < sendlen ) { // wait for the final part*
* delay(1); if( i-- == 0 ) return 0;
for( i=4; i<4+sendlen; i++ )
#ifdef DEBUG*
* Serial.println(“got all”);
#endif*
* return 4+sendlen;
This would be fantasitic, and I think it would be a great little project, as I imagine a lot of people may want i2c serial support in maxmsp, but with digital pin access also.
Many many thanks!_
