Hello everyone
I want to mix java script and HTML and CSS codes with Arduino codes but, i don’t know why Arduino IDE sends me an error when I add javascript but, for adding HTML and CSS there is not any problem.
I put my codes here and I will really be appreciate anyone which understand what is the problem in these codes and fix it for me.
#include <ESP8266WiFi.h>
const char* ssid = “xxxx”;
const char* password = “xxxx”;
WiFiServer server(80);
delay(10);
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
Serial.println(“WiFi connected”);
server.begin();
Serial.println(“Server started”);
WiFiClient client = server.available();
if (!client) {
return;
Serial.println(“new client”);
while (!client.available()) {
delay(1);
String req = client.readStringUntil(’\r’);
Serial.println(req);
client.flush();
String s;
s += “”;
s += “”;
s += " .slidecontainer { width: 60%;}.slider { -webkit-appearance: none; width: 100%; height: 25px; background: #d3d3d3; outline: none; opacity: 0.7; -webkit-transition: .2s; transition: opacity .2s;}.slider:hover { opacity: 1;}.slider::-webkit-slider-thumb { -webkit-appearance: none; appearance: none; width: 25px; height: 25px; background: #4CAF50; cursor: pointer;}.slider::-moz-range-thumb { width: 25px; height: 25px; background: #4CAF50; cursor: pointer;}";
s += “
Custom Range Slider
”;s += “<input type=“range” min=“1” max=“5” value=“1” class=“slider” oninput=“myFunction(this.value)”>
Value: <span id=“demo”>
”;s += “”;
function myFunction(val) {
switch (val) {
case “1”:
document.getElementById(“demo”).innerHTML = “OFF”;
case “2”:
document.getElementById(“demo”).innerHTML = “I got position number 2”;
case “3”:
document.getElementById(“demo”).innerHTML = “I need a break”;
case “4”:
document.getElementById(“demo”).innerHTML = “I got number 4”;
case “5”:
document.getElementById(“demo”).innerHTML = “This is the last position in range”;
s += “< / script >”;
s += “< / body >”;
s += “< / html >”;
client.print(s);
delay(1);
Serial.println(“Client disconnected”);
