I couldn't decide if this question belonged best in the 'Programming' , 'Network-I2C', or 'Sensors' thread, so I'm placing it here. (Moderator, please move to where most appropriate).
As the topic suggests, I'm trying to combine I2C RTC code with interrupt pulse counter code. I'm using the ChronoDot/DS3231. As a quick feasibility test, I grabbed the Chronodot code from Adafruit and the interrupt pulse counting code from elsewhere online. I'm not using any custom libraries.
The RTC code works fine on its own, as does the interrupt code, but they do not work well together. For example, if I comment out each other's code, the other will work, and visaversa. When added together, I can get the serial monitor to display one time and one pulse frequency loop iterations worth, but it doesn't continue. I've tried replacing the Chronodot code with the RTClib.h code, however the main loop still hangs after 1 iteration.
I've also tried replacing the interrupt pulse counting code with the FreqCounter.h library, which does work, however, I prefer not to use custom libraries and would like to know what is going wrong with my seemingly simple code. Is the interrupt not detaching? Is a certain delay needed in one place to allow for something to be available? I'm sure someone must have run into this before, but my search came up empty. Any help would be most appreciated.
The code is as follows,
#include <Wire.h>
int seconds;
int minutes;
int hours;
volatile int Counter;
int Time1;
int Time2;
float PulseFrequency;
seconds = 0;
minutes = 0;
hours = 0;
Counter = 0;
Time1 = 0;
Time2 = 0;
PulseFrequency = 0.0;
Wire.begin();
Wire.beginTransmission(0x68); // Hex I2C address of DS3231
Wire.send(0x0E); // Select register
Wire.send(0b00011100); // Write register bitmap, bit 7 is /EOSC
Wire.endTransmission();
pinMode(2, INPUT); //Set Arduino pin D2 as an input
digitalWrite(2, LOW); //Set pin D2's pull-up resistor off since not using switched (Reed/Hall) flow meter
attachInterrupt(0, CounterFunction, RISING); // Using interrupt 0 on pin D2 as a hardware pulse counter
// Get RTC time
Wire.beginTransmission(0x68); // 0x68 is DS3231 device address
Wire.send(0); // Start at register 0
Wire.requestFrom(0x68, 3); // Request three bytes (seconds, minutes, hours)
while(Wire.available())
seconds = Wire.receive(); // get seconds
minutes = Wire.receive(); // get minutes
hours = Wire.receive(); // get hours
seconds = (((seconds & 0b11110000)>>4)*10 + (seconds & 0b00001111)); // Convert BCD to decimal
minutes = (((minutes & 0b11110000)>>4)*10 + (minutes & 0b00001111)); // Convert BCD to decimal
hours = (((hours & 0b00110000)>>4)*10 + (hours & 0b00001111)); // Convert BCD to decimal in 24-hour mode
Serial.print("Time: ");
Serial.print(hours); Serial.print(":"); Serial.print(minutes); Serial.print(":"); Serial.println(seconds);
// Interrupt-based frequency counter
Counter = 0; //Reset Counter to 0
sei(); //Enable interrupt
Time1 = millis(); //millis() time is in milliseconds
delay (2000); //Count pulses for 2000 ms (2000 ms works well for the 20-1000 Hz counting range)
cli(); //Disable interrupt (so the Arduino can do other things)
Time2 = millis();
PulseFrequency = (1000.0 * Counter / (Time2 - Time1)); //Result is in pulses/second
Serial.print("Pulse Frequency (Hz): ");
Serial.println(PulseFrequency,2);
void CounterFunction () { //This is the function that the interupt calls when enabled/attached
Counter++; //This function increments the counter when it sees a rising/falling edge pair
