Hello everybody,
I just finish temperature and humidity sensors with MKR 1000 and now, I would like optimise the
consumption power with ArduinoLowPower.h librairie
So, I put at the End to the loop, LowPower.sleep(2000); command, but when the MKR wake up, I loss totaly the serial communication, and never work again, and I need to reboot the board.
Have you a idea ?
Thank you for your help
My code :
TimedWakeup
This sketch demonstrates the usage of Internal Interrupts to wakeup a chip in sleep mode.
Sleep modes allow a significant drop in the power usage of a board while it does nothing waiting for an event to happen. Battery powered application can take advantage of these modes to enhance battery life significantly.
In this sketch, the internal RTC will wake up the processor every 2 seconds.
Please note that, if the processor is sleeping, a new sketch can't be uploaded. To overcome this, manually reset the board (usually with a single or double tap to the RESET button)
This example code is in the public domain.
#include "ArduinoLowPower.h"
pinMode(LED_BUILTIN, OUTPUT);
// Uncomment this function if you wish to attach function dummy when RTC wakes up the chip
// LowPower.attachInterruptWakeup(RTC_ALARM_WAKEUP, dummy, CHANGE);
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial1.println("Start program");
delay(5000);
digitalWrite(LED_BUILTIN, HIGH);
digitalWrite(LED_BUILTIN, LOW);
// Triggers a 2000 ms sleep (the device will be woken up only by the registered wakeup sources and by internal RTC)
// The power consumption of the chip will drop consistently
Serial.println("sleep");
Serial.println("wake");
void dummy() {
// This function will be called once on device wakeup
// You can do some little operations here (like changing variables which will be used in the loop)
// Remember to avoid calling delay() and long running functions since this functions executes in interrupt context
