I am able to connect to wifi fine as well as reconnect when the connection is lost. This has been tested via router restart and I can confirm that WiFi.status() reports a disconnected status during this event. The web server responds via IP and MDNS fine and functions for a good many hours but inevitably (<8hrs) stops responding. At that point I no longer see that the IP is leased by the router, not surprisingly it does not respond to pings because the IP is unroutable. The rest of the program continues to run fine; not stuck in an endless loop. A serial debug reports that the connection is fine:
18:50:45.990 → WiFi Status: 3
18:50:45.990 → SSID: ROSOLA-2.4G
18:50:45.990 → IP Address: 192.168.1.107
18:50:45.990 → signal strength (RSSI):-42 dBm
Interestingly if I then restart the router, the WiFi.status() reports a disconnected status and reconnect logic brings it back online without issue once the router is back up.
Firmware is updated to 19.6.1
WiFi101 Library is version 0.16.0
Router is TPLink Archer C9 (plain old DHCP config)
I have read many related topics but unfortunately have not found an answer. Any thoughts?
I am close to forcing a connection reconnect on a periodic basis or perhaps have it ping it’s host to test it is connected rather than trusting WiFi.status() but these sort of work-arounds should not be necessary.
DEBUG CODE:
void printWiFiStatus() {
//print wifi status
Serial.print("WiFi Status: ");
Serial.println(WiFi.status());
// print the SSID of the network you're attached to:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print your WiFi shield's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.print(rssi);
Serial.println(" dBm");
CONNECT CODE:
void setupWifi() {
// wait while not connected
//connected, so start server & MDNS
server.begin();
if (!mdnsResponder.begin(mdnsName)) {
Serial.println("Failed to start MDNS responder!");
while(1);
Serial.print("Server listening at http://");
Serial.print(mdnsName);
Serial.println(".local/");
RECONNECT CODE:
//attempt to reconnect to wifi if disconnected
if ( WiFi.status() != WL_CONNECTED ) {
Serial.println("attempting to reconnect to wifi");
WiFi.end();
WiFi.beginProvision();
delay(5000);
if ( WiFi.status() != WL_CONNECTED) {
Serial.println("reconnect failed");
}else{
Serial.println("reconnected successful, starting server and dns");
server.begin();
mdnsResponder.begin(mdnsName);
WEB SERVER CODE
void operateWebServer(){
// Call the update() function on the MDNS responder every loop iteration to
// make sure it can detect and respond to name requests.
mdnsResponder.poll();
// listen for incoming clients
WiFiClient client = server.available();
if (client) {
// loop while the client's connected
unsigned long actualTime = millis();
while (client.connected()) {
// exit loop if stuck here.
if (millis() > actualTime + 20000) {
Serial.println("Timeout. Forcing client to exit.");
if (client.available()) {
//get request
String c = client.readString();
Serial.print(c);
// HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
// and a content-type so the client knows what's coming, then a blank line:
client.println("Content-type:text/html");
client.println();
client.println("HTML STUFF");
// The HTTP response ends with another blank line:
client.println();
// break out of the while loop:
// close the connection:
client.flush();
client.stop();
Serial.println("client disonnected");
