I'm trying to get anything at all running on two new MKR WiFi 1010 units. Both are behaving identically. I'm using Arduino 1.8.12 on OSX 10.14.6. I have Arduino SAMD Boards (32-bits ARM Cortex-M0+) version 1.8.6 installed in Boards Manager.
I'm trying to uplaod the example app "Blink". Every attempt to upload fails with the below errors. I've tried it with and without double-tapping reset before uploading.
Please let me know what I can do to make these boards accept a program.
Thanks, Sean
Arduino: 1.8.12 (Mac OS X), Board: "Arduino MKR WiFi 1010"
Sketch uses 12260 bytes (4%) of program storage space. Maximum is 262144 bytes.
Global variables use 2952 bytes of dynamic memory.
Forcing reset using 1200bps open/close on port /dev/cu.usbmodem5D101
PORTS {/dev/cu.Bluetooth-Incoming-Port, /dev/cu.usbmodem5D101, /dev/tty.Bluetooth-Incoming-Port, /dev/tty.usbmodem5D101, } / {/dev/cu.Bluetooth-Incoming-Port, /dev/cu.usbmodem5D101, /dev/tty.Bluetooth-Incoming-Port, /dev/tty.usbmodem5D101, } => {}
Uploading using selected port: /dev/cu.usbmodem5D101
/Users/ssuchter/Library/Arduino15/packages/arduino/tools/bossac/1.7.0-arduino3/bossac -i -d --port=cu.usbmodem5D101 -U true -i -e -w -v /var/folders/_g/4kgjcg251m5fmtvcxsbfh_700000gn/T/arduino_build_184883/Blink.ino.bin -R
Set binary mode
readWord(addr=0)=0x20007ffc
readWord(addr=0xe000ed00)=0x410cc601
readWord(addr=0x41002018)=0x10010305
version()=v2.0 [Arduino:XYZ] Mar 19 2018 09:45:14
chipId=0x10010005
Connected at 921600 baud
Atmel SMART device 0x10010005 found
write(addr=0x20004000,size=0x34)
writeWord(addr=0x20004030,value=0x10)
writeWord(addr=0x20004020,value=0x20008000)
Device : ATSAMD21G18A
Chip ID : 10010005
Version : v2.0 [Arduino:XYZ] Mar 19 2018 09:45:14
Address : 8192
Pages : 3968
Page Size : 64 bytes
Total Size : 248KB
Planes : 1
Lock Regions : 16
Locked : readWord(addr=0x41004020)=0xffff
none
readWord(addr=0x41004018)=0
Security : false
Boot Flash : true
readWord(addr=0x40000834)=0
BOD : false
BOR : false
Arduino : FAST_CHIP_ERASE
Arduino : FAST_MULTI_PAGE_WRITE
Arduino : CAN_CHECKSUM_MEMORY_BUFFER
Erase flash
chipErase(addr=0x2000)
done in 0.822 seconds
Write 12260 bytes to flash (192 pages)
write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0x2000, size=0x1000)
SAM-BA operation failed
An error occurred while uploading the sketch
[========== ] 33% (64/192 pages)write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0x3000, size=0x1000)
[==================== ] 66% (128/192 pages)write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0x4000, size=0x1000)
option enabled in File -> Preferences.
