MKR 1010 WiFi and ArduinoModbus.h
I use this scatch to send Data to an S7-1215 PLC via Modbus TCP and WiFi. My code is obviusly not correct. After e few minutes MKR1010 WiFi stop processing. I need help from an experienced programmer. Thanks in advance.
// This scatch works not properly!
// Communication Arduino Modbus TCP over WiFi to S7-1215
// 10 times per second the S7 reads the holding register 0 - 9 (10) cycle time S7 is constantly 2 ms
// when connection lost, reconnect works fine
// the Problem:
// works only a few minutes then arduino stop processing
// the faster the intervalls, the shorter this working time
// while processing the arduino stop counting after about 12 s for the duration of about 1 s
#include <SPI.h>
#include <WiFiNINA.h>
#include <ArduinoRS485.h>
#include <ArduinoModbus.h>
#include "arduino_secrets.h"
char ssid[] = SECRET_SSID;
char pass[] = SECRET_PASS;
int keyIndex = 0;
int status = WL_IDLE_STATUS;
WiFiServer wifiServer(502);
ModbusTCPServer modbusTCPServer;
uint16_t course = 5500;                    // testvalue
unsigned long h_previousMillis = 0;        // will store last time for delay updating holdingReisters
const long h_interval = 5;                 // intervall for update holdingRegisters
unsigned long u_previousMillis = 0;        // will store last time for update Data
const long u_interval = 1;                 // intervall for update Data
  while (status != WL_CONNECTED) {
    status = WiFi.begin(ssid, pass);
    delay(5000);                           // wait 5 seconds for connection:
  wifiServer.begin();
   if (!modbusTCPServer.begin()) {         // start the Modbus TCP server
    while (1);
// configure HoldingRegister ab 40001 / start adress 0, 20 Adressen lang
  modbusTCPServer.configureHoldingRegisters(0x0, 0x14);   // or decimal(0, 20)
// attempt to connect to WiFi network: if connection lost
    delay(5000);
  WiFiClient client = wifiServer.available();    // listen for incoming clients
  if (client) {                             // a new client connected
    modbusTCPServer.accept(client);         // let the Modbus TCP accept the connection
    while (client.connected()) {
      modbusTCPServer.poll();               // poll for Modbus TCP requests, while client connected
      updatemodbusloop();                   // update holdingReister
      updatedataloop();                     // counts every loop
//   stop WiFi when connection lost
       if (WiFi.status() != WL_CONNECTED) {
       WiFi.disconnect();
void updatemodbusloop() {
 unsigned long h_currentMillis = millis();
  if (h_currentMillis - h_previousMillis >= h_interval) {
    h_previousMillis = h_currentMillis;
    modbusTCPServer.holdingRegisterWrite(4, course);
void updatedataloop(){
 unsigned long u_currentMillis = millis();
  if (u_currentMillis - u_previousMillis >= u_interval) {
    u_previousMillis = u_currentMillis;
    course = course + 1;
Ah read this:
Means ... this lib doesn´t really work with MKR1010. Development is obviously not finished in development. For me it´s a bit angry, I´ve seen this lib and I bought this MKR1010 only for this application. Now I hop for new version.
