Hi
I try to connect two different mqtt brokers
MqttClient mqttClient_1(sslClient);
MqttClient mqttClient_2(sslClient);
//broker 1
if (!mqttClient_1.connected()) {
// MQTT client 1 is disconnected, connect
connectMQTT_1);
mqttClient_1.poll();
publishMessage_1();
delay (5000);
//broker 2
if (!mqttClient_2.connected()) {
// MQTT client is disconnected, connect
connectMQTT_2();
mqttClient_2.poll();
publishMessage_2();
delay(5000);
connectMQTT function and publishMessage function are let me say "standard" functions taken from Arduino example.
void connectMQTT_1() {
while (!mqttClient_1.connect(broker_1, 8883)) {
// failed, retry
Serial.print(".");
Serial.println(mqttClient_1.connectError());
delay(5000);
Serial.println("You're connected to the MQTT broker ");
// subscribe to a topic
mqttClient_1.subscribe("devices/" + deviceId + "/messages/devicebound/#");
connectMQTT_2() works with broker2 and another topic
What happend is that (mqttClient_1.connected) in loop function is FALSE after publishMessage_2 and viceversa.
So every time mqttclient attempt to reconnect
It seems that when I publish to Broker2 I lose my connection to Broker 1
and vice versa
What's wrong?
PublishMessage is "standard"
void publishMessage_1() {
StaticJsonDocument<300> doc;
Serial.println("Publishing message");
float temperature = ENV.readTemperature() + TempCalibration;
float humidity = ENV.readHumidity();
float pressure = ENV.readPressure();
float illuminance = ENV.readIlluminance();
// send message, the Print interface can be used to set the message contents
mqttClient_1.beginMessage("devices/" + deviceId + "/messages/events/");
doc["deviceId"] = deviceId;
doc["timestamp"] = getTime();
doc["temp"] = temperature;
doc["humidity"] = humidity;
doc["pressure"] = pressure;
doc["illuminance"] = illuminance;
Serial.print ("Azure IOT HUB :");
serializeJson(doc,Serial);
serializeJson(doc, mqttClient_1);
mqttClient_1.endMessage();
Serial.println ("OK _IOT");
Publish Message for broker 2, works with mqqtClient_2
