Hi Guys,
Thanks for your time.
I succesfully set up the Arduino MKR 1010 so turn one some lights using Hombridge installed on a Raspberry Pi. Everything works fine if I let the MKR handle the connection but when I set up a static IP address Homebridge is unable to find the MRK 1010.
This is the error message that shows up in Hombridge: "HTTP set power function failed: connect EHOSTUNREACH 192.168.0.201:80".
Note: I changed the IP address in the config.json file before setting up the static IP address in the MKR so this shouldnt cause the issue
If I comment the WiFi.config line an revert the changes in the config.json file everthing works fine again.
I'll parecieate any help on this matter
#include <SPI.h>
#include <WiFiNINA.h>
#include "arduino_secrets.h"
///////please enter your sensitive data in the Secret tab/arduino_secrets.h
char ssid[] = SECRET_SSID; // your network SSID (name)
char pass[] = SECRET_PASS; // your network password (use for WPA, or use as key for WEP)
int status = WL_IDLE_STATUS; // the Wifi radio's status
String readString;
IPAddress ip(192,168,0,201);
IPAddress DNS(100,72,3,101);
IPAddress gateway(192,168,0,1);
IPAddress subnet(255,255,255,0);
WiFiServer server(80);
//Initialize serial and wait for port to open:
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
// attempt to connect to Wifi network:
while (status != WL_CONNECTED) {
Serial.print("Attempting to connect to WPA SSID: ");
Serial.println(ssid);
// Connect to WPA/WPA2 network:
status = WiFi.begin(ssid, pass);
WiFi.config(ip, DNS, gateway, subnet);
// wait 10 seconds for connection:
delay(10000);
// you're connected now, so print out the data:
Serial.print("You're connected to the network");
printCurrentNet();
printWifiData();
server.begin();
