Hello, I have a problem with the upload and the COM interface under Windows 10.
Apparently the driver is not working properly. A new installation and also another version of the IDE brought no improvement. Everything works fine on a Windows 7 PC.
The serial monitor does not work either. Nothing goes. What am I doing wrong?
Thanks for your help!
A.
Erzwinge Reset durch öffnen/schließen mit 1200 bps auf dem Port COM4
processing.app.debug.RunnerException
at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:152)
at cc.arduino.UploaderUtils.upload(UploaderUtils.java:77)
at processing.app.SketchController.upload(SketchController.java:732)
at processing.app.SketchController.exportApplet(SketchController.java:703)
at processing.app.Editor$UploadHandler.run(Editor.java:2042)
at java.lang.Thread.run(Thread.java:748)
Caused by: processing.app.SerialException: Fehler beim Ansprechen des seriellen Ports “COM4”.
at processing.app.Serial.touchForCDCReset(Serial.java:107)
at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:136)
… 5 more
Caused by: jssc.SerialPortException: Port name - COM4; Method name - openPort(); Exception type - Port busy.
at jssc.SerialPort.openPort(SerialPort.java:164)
at processing.app.Serial.touchForCDCReset(Serial.java:101)
… 6 more
