# MKR 1400 modem died?
**URL:** <https://forum.arduino.cc/t/mkr-1400-modem-died/571879>\
**Category:** MKR GSM 1400\
**Created:** [February 4, 2019, 8:47am UTC](https://forum.arduino.cc/t/mkr-1400-modem-died/571879 "2019-02-04T08:47:14Z")\
**Posts on this page:** 5\
**Page:** 1
<div class="post-metadata">
**Author:** ![elisedd](https://avatars.discourse-cdn.com/v4/letter/e/90db22/32.png) [@elisedd](https://forum.arduino.cc/u/elisedd)\
**Post date:** [February 4, 2019, 8:47am UTC](https://forum.arduino.cc/t/mkr-1400-modem-died/571879/1 "2019-02-04T08:47:14Z")
</div>
after a further debuging session yesterday trying to figure out how to get the SIM enabeld again ( see thread [strange crashes under poor receiving condition - MKRGSM1400 - Arduino Forum](https://forum.arduino.cc/index.php?topic=593726.0)) I had some new "insides" with the AT+USIMSTAT command... It reports 0 (no SIM present) but I logged in before with AT+CPIN. After the +USIMSTAT I was - how ever able to login to the network with a AT+COPS=0.
I was happy to find the error - but unfortunatly not very long. After a reset of the modem it seems that the modem died. Even with the passthrue programm I'm now not able to access the modem anymore. After a couple of AT's it just sends back an returned qustionmark.
For me it looks like a bit that somthing screwed up the bautrate settings of the Modem. How ever changing that on adruino site doesn't help.
Does anyone have an Idea?
**Author:** ![smgs](https://dub1.discourse-cdn.com/arduino/user_avatar/forum.arduino.cc/smgs/32/223950_2.png) [@smgs](https://forum.arduino.cc/u/smgs)\
**Post date:** [February 5, 2019, 3:10am UTC](https://forum.arduino.cc/t/mkr-1400-modem-died/571879/2 "2019-02-05T03:10:24Z")
</div>
Hi Elisedd, are you using the included examples for the MKR GSM 1400, pretty positive there is a sketch in there to reset the BAUD rate.
What happens if you load a different example like blink, can you make the onboard LED flash?
Cheers
**Post date:** [February 5, 2019, 12:39pm UTC](https://forum.arduino.cc/t/mkr-1400-modem-died/571879/3 "2019-02-05T12:39:41Z")
</div>
Yes I used a couple of the included examples - none of them are working anymore... And as I said - with the passthrue example I only get this "¿" back after some AT's... The other stall normaly after "MODEM.begin()"
**Author:** ![lavignema](https://avatars.discourse-cdn.com/v4/letter/l/c67d28/32.png) [@lavignema](https://forum.arduino.cc/u/lavignema)\
**Post date:** [March 4, 2019, 1:44am UTC](https://forum.arduino.cc/t/mkr-1400-modem-died/571879/4 "2019-03-04T01:44:45Z")
</div>
Try this sketch. It allows you to pass modem commands directly from the serial interface. Be sure to set the serial interface to terminate with carriage return and newline or the AT commands will not be interpreted by the modem.
```cpp
unsigned long baud = 9600;
  // reset the ublox module
  pinMode(GSM_RESETN, OUTPUT);
  digitalWrite(GSM_RESETN, HIGH);
  delay(100);
  digitalWrite(GSM_RESETN, LOW);
  Serial.begin(baud);
  SerialGSM.begin(baud);
  if (Serial.available()) {
    SerialGSM.write(Serial.read());
  if (SerialGSM.available()) {
    Serial.write(SerialGSM.read());
**Post date:** [May 7, 2021, 11:53am UTC](https://forum.arduino.cc/t/mkr-1400-modem-died/571879/5 "2021-05-07T11:53:36Z")
</div>
Closed on May 7, 2021, 11:53am UTC
