I use a mkr1400 as a shield + Mkr GPS and until now, all was working well particularly when I was uploading sketches.
Since today, after install tinyGPSPlus (I don't know if it is linked but I mention that), the upload of a simple sketch on the mkr1400 shield spend a long time (may be 2 minutes) and finishes by printing "no device found on ttyACM0". I uninstalled tinyGPSplus library but the problem stills be so I supposed that it was not the problem.
I tried to add all rights to /dev/ttyACM0 :
chmod a+rwx /dev/ttyACM0
I checked the baud rate of /dev/ttyACM0 after the error :
stty -F /dev/ttyACM0
speed 115200 baud; line = 0;
min = 0; time = 0;
-brkint -icrnl -imaxbel
-opost
-isig -icanon -iexten -echo -echoe -echok -echoctl -echoke
Thank you for your help
I add the detailed output of the compilation + upload:
Arduino : 1.8.15 (Linux), Carte : "Arduino MKR GSM 1400"
/snap/arduino/61/arduino-builder -dump-prefs -logger=machine -hardware /snap/arduino/61/hardware -hardware /home/audric/snap/arduino/61/.arduino15/packages -tools /snap/arduino/61/tools-builder -tools /snap/arduino/61/hardware/tools/avr -tools /home/audric/snap/arduino/61/.arduino15/packages -built-in-libraries /snap/arduino/61/libraries -libraries /home/audric/snap/arduino/current/Arduino/libraries -fqbn=arduino:samd:mkrgsm1400 -vid-pid=2341_8052 -ide-version=10815 -build-path /tmp/arduino_build_968385 -warnings=none -build-cache /tmp/arduino_cache_685531 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arm-none-eabi-gcc.path=/home/audric/snap/arduino/61/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4 -prefs=runtime.tools.arm-none-eabi-gcc-7-2017q4.path=/home/audric/snap/arduino/61/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4 -prefs=runtime.tools.arduinoOTA.path=/home/audric/snap/arduino/61/.arduino15/packages/arduino/tools/arduinoOTA/1.2.1 -prefs=runtime.tools.arduinoOTA-1.2.1.path=/home/audric/snap/arduino/61/.arduino15/packages/arduino/tools/arduinoOTA/1.2.1 -prefs=runtime.tools.openocd.path=/home/audric/snap/arduino/61/.arduino15/packages/arduino/tools/openocd/0.10.0-arduino7 -prefs=runtime.tools.openocd-0.10.0-arduino7.path=/home/audric/snap/arduino/61/.arduino15/packages/arduino/tools/openocd/0.10.0-arduino7 -prefs=runtime.tools.bossac.path=/home/audric/snap/arduino/61/.arduino15/packages/arduino/tools/bossac/1.7.0-arduino3 -prefs=runtime.tools.bossac-1.7.0-arduino3.path=/home/audric/snap/arduino/61/.arduino15/packages/arduino/tools/bossac/1.7.0-arduino3 -prefs=runtime.tools.CMSIS.path=/home/audric/snap/arduino/61/.arduino15/packages/arduino/tools/CMSIS/4.5.0 -prefs=runtime.tools.CMSIS-4.5.0.path=/home/audric/snap/arduino/61/.arduino15/packages/arduino/tools/CMSIS/4.5.0 -prefs=runtime.tools.CMSIS-Atmel.path=/home/audric/snap/arduino/61/.arduino15/packages/arduino/tools/CMSIS-Atmel/1.2.0 -prefs=runtime.tools.CMSIS-Atmel-1.2.0.path=/home/audric/snap/arduino/61/.arduino15/packages/arduino/tools/CMSIS-Atmel/1.2.0 -verbose /home/audric/Arduino/LoraDuplexMkr1400/LoraDuplexMkr1400.ino
/snap/arduino/61/arduino-builder -compile -logger=machine -hardware /snap/arduino/61/hardware -hardware /home/audric/snap/arduino/61/.arduino15/packages -tools /snap/arduino/61/tools-builder -tools /snap/arduino/61/hardware/tools/avr -tools /home/audric/snap/arduino/61/.arduino15/packages -built-in-libraries /snap/arduino/61/libraries -libraries /home/audric/snap/arduino/current/Arduino/libraries -fqbn=arduino:samd:mkrgsm1400 -vid-pid=2341_8052 -ide-version=10815 -build-path /tmp/arduino_build_968385 -warnings=none -build-cache /tmp/arduino_cache_685531 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arm-none-eabi-gcc.path=/home/audric/snap/arduino/61/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4 -prefs=runtime.tools.arm-none-eabi-gcc-7-2017q4.path=/home/audric/snap/arduino/61/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4 -prefs=runtime.tools.arduinoOTA.path=/home/audric/snap/arduino/61/.arduino15/packages/arduino/tools/arduinoOTA/1.2.1 -prefs=runtime.tools.arduinoOTA-1.2.1.path=/home/audric/snap/arduino/61/.arduino15/packages/arduino/tools/arduinoOTA/1.2.1 -prefs=runtime.tools.openocd.path=/home/audric/snap/arduino/61/.arduino15/packages/arduino/tools/openocd/0.10.0-arduino7 -prefs=runtime.tools.openocd-0.10.0-arduino7.path=/home/audric/snap/arduino/61/.arduino15/packages/arduino/tools/openocd/0.10.0-arduino7 -prefs=runtime.tools.bossac.path=/home/audric/snap/arduino/61/.arduino15/packages/arduino/tools/bossac/1.7.0-arduino3 -prefs=runtime.tools.bossac-1.7.0-arduino3.path=/home/audric/snap/arduino/61/.arduino15/packages/arduino/tools/bossac/1.7.0-arduino3 -prefs=runtime.tools.CMSIS.path=/home/audric/snap/arduino/61/.arduino15/packages/arduino/tools/CMSIS/4.5.0 -prefs=runtime.tools.CMSIS-4.5.0.path=/home/audric/snap/arduino/61/.arduino15/packages/arduino/tools/CMSIS/4.5.0 -prefs=runtime.tools.CMSIS-Atmel.path=/home/audric/snap/arduino/61/.arduino15/packages/arduino/tools/CMSIS-Atmel/1.2.0 -prefs=runtime.tools.CMSIS-Atmel-1.2.0.path=/home/audric/snap/arduino/61/.arduino15/packages/arduino/tools/CMSIS-Atmel/1.2.0 -verbose /home/audric/Arduino/LoraDuplexMkr1400/LoraDuplexMkr1400.ino
Using board 'mkrgsm1400' from platform in folder: /home/audric/snap/arduino/61/.arduino15/packages/arduino/hardware/samd/1.8.13
Using core 'arduino' from platform in folder: /home/audric/snap/arduino/61/.arduino15/packages/arduino/hardware/samd/1.8.13
Detecting libraries used...
/home/audric/snap/arduino/61/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_SAMD_MKRGSM1400 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8052 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR GSM 1400\"" -DUSE_BQ24195L_PMIC -I/home/audric/snap/arduino/61/.arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/ -I/home/audric/snap/arduino/61/.arduino15/packages/arduino/tools/CMSIS-Atmel/1.2.0/CMSIS/Device/ATMEL/ -I/home/audric/snap/arduino/61/.arduino15/packages/arduino/hardware/samd/1.8.13/cores/arduino/api/deprecated -I/home/audric/snap/arduino/61/.arduino15/packages/arduino/hardware/samd/1.8.13/cores/arduino/api/deprecated-avr-comp -I/home/audric/snap/arduino/61/.arduino15/packages/arduino/hardware/samd/1.8.13/cores/arduino -I/home/audric/snap/arduino/61/.arduino15/packages/arduino/hardware/samd/1.8.13/variants/mkrgsm1400 /tmp/arduino_build_968385/sketch/LoraDuplexMkr1400.ino.cpp -o /dev/null
Alternatives for MKRGSM.h: [MKRGSM@1.5.0]
ResolveLibrary(MKRGSM.h)
-> candidates: [MKRGSM@1.5.0]
/home/audric/snap/arduino/61/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_SAMD_MKRGSM1400 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8052 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR GSM 1400\"" -DUSE_BQ24195L_PMIC -I/home/audric/snap/arduino/61/.arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/ -I/home/audric/snap/arduino/61/.arduino15/packages/arduino/tools/CMSIS-Atmel/1.2.0/CMSIS/Device/ATMEL/ -I/home/audric/snap/arduino/61/.arduino15/packages/arduino/hardware/samd/1.8.13/cores/arduino/api/deprecated -I/home/audric/snap/arduino/61/.arduino15/packages/arduino/hardware/samd/1.8.13/cores/arduino/api/deprecated-avr-comp -I/home/audric/snap/arduino/61/.arduino15/packages/arduino/hardware/samd/1.8.13/cores/arduino -I/home/audric/snap/arduino/61/.arduino15/packages/arduino/hardware/samd/1.8.13/variants/mkrgsm1400 -I/home/audric/snap/arduino/current/Arduino/libraries/MKRGSM/src /tmp/arduino_build_968385/sketch/LoraDuplexMkr1400.ino.cpp -o /dev/null
Alternatives for Arduino_MKRGPS.h: [Arduino_MKRGPS@1.0.0]
ResolveLibrary(Arduino_MKRGPS.h)
-> candidates: [Arduino_MKRGPS@1.0.0]
/home/audric/snap/arduino/61/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_SAMD_MKRGSM1400 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8052 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR GSM 1400\"" -DUSE_BQ24195L_PMIC -I/home/audric/snap/arduino/61/.arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/ -I/home/audric/snap/arduino/61/.arduino15/packages/arduino/tools/CMSIS-Atmel/1.2.0/CMSIS/Device/ATMEL/ -I/home/audric/snap/arduino/61/.arduino15/packages/arduino/hardware/samd/1.8.13/cores/arduino/api/deprecated -I/home/audric/snap/arduino/61/.arduino15/packages/arduino/hardware/samd/1.8.13/cores/arduino/api/deprecated-avr-comp -I/home/audric/snap/arduino/61/.arduino15/packages/arduino/hardware/samd/1.8.13/cores/arduino -I/home/audric/snap/arduino/61/.arduino15/packages/arduino/hardware/samd/1.8.13/variants/mkrgsm1400 -I/home/audric/snap/arduino/current/Arduino/libraries/MKRGSM/src -I/home/audric/snap/arduino/current/Arduino/libraries/Arduino_MKRGPS/src /tmp/arduino_build_968385/sketch/LoraDuplexMkr1400.ino.cpp -o /dev/null
Alternatives for Wire.h: [Wire@1.0]
ResolveLibrary(Wire.h)
-> candidates: [Wire@1.0]
/home/audric/snap/arduino/61/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_SAMD_MKRGSM1400 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8052 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR GSM 1400\"" -DUSE_BQ24195L_PMIC -I/home/audric/snap/arduino/61/.arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/ -I/home/audric/snap/arduino/61/.arduino15/packages/arduino/tools/CMSIS-Atmel/1.2.0/CMSIS/Device/ATMEL/ -I/home/audric/snap/arduino/61/.arduino15/packages/arduino/hardware/samd/1.8.13/cores/arduino/api/deprecated -I/home/audric/snap/arduino/61/.arduino15/packages/arduino/hardware/samd/1.8.13/cores/arduino/api/deprecated-avr-comp -I/home/audric/snap/arduino/61/.arduino15/packages/arduino/hardware/samd/1.8.13/cores/arduino -I/home/audric/snap/arduino/61/.arduino15/packages/arduino/hardware/samd/1.8.13/variants/mkrgsm1400 -I/home/audric/snap/arduino/current/Arduino/libraries/MKRGSM/src -I/home/audric/snap/arduino/current/Arduino/libraries/Arduino_MKRGPS/src -I/home/audric/snap/arduino/61/.arduino15/packages/arduino/hardware/samd/1.8.13/libraries/Wire /tmp/arduino_build_968385/sketch/LoraDuplexMkr1400.ino.cpp -o /dev/null
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
-> candidates: [SPI@1.0]
/home/audric/snap/arduino/61/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_SAMD_MKRGSM1400 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8052 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR GSM 1400\"" -DUSE_BQ24195L_PMIC -I/home/audric/snap/arduino/61/.arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/ -I/home/audric/snap/arduino/61/.arduino15/packages/arduino/tools/CMSIS-Atmel/1.2.0/CMSIS/Device/ATMEL/ -I/home/audric/snap/arduino/61/.arduino15/packages/arduino/hardware/samd/1.8.13/cores/arduino/api/deprecated -I/home/audric/snap/arduino/61/.arduino15/packages/arduino/hardware/samd/1.8.13/cores/arduino/api/deprecated-avr-comp -I/home/audric/snap/arduino/61/.arduino15/packages/arduino/hardware/samd/1.8.13/cores/arduino -I/home/audric/snap/arduino/61/.arduino15/packages/arduino/hardware/samd/1.8.13/variants/mkrgsm1400 -I/home/audric/snap/arduino/current/Arduino/libraries/MKRGSM/src -I/home/audric/snap/arduino/current/Arduino/libraries/Arduino_MKRGPS/src -I/home/audric/snap/arduino/61/.arduino15/packages/arduino/hardware/samd/1.8.13/libraries/Wire -I/home/audric/snap/arduino/61/.arduino15/packages/arduino/hardware/samd/1.8.13/libraries/SPI /tmp/arduino_build_968385/sketch/LoraDuplexMkr1400.ino.cpp -o /dev/null
Alternatives for LoRa.h: [LoRa@0.8.0]
ResolveLibrary(LoRa.h)
-> candidates: [LoRa@0.8.0]
/home/audric/snap/arduino/61/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_SAMD_MKRGSM1400 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8052 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR GSM 1400\"" -DUSE_BQ24195L_PMIC -I/home/audric/snap/arduino/61/.arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/ -I/home/audric/snap/arduino/61/.arduino15/packages/arduino/tools/CMSIS-Atmel/1.2.0/CMSIS/Device/ATMEL/ -I/home/audric/snap/arduino/61/.arduino15/packages/arduino/hardware/samd/1.8.13/cores/arduino/api/deprecated -I/home/audric/snap/arduino/61/.arduino15/packages/arduino/hardware/samd/1.8.13/cores/arduino/api/deprecated-avr-comp -I/home/audric/snap/arduino/61/.arduino15/packages/arduino/hardware/samd/1.8.13/cores/arduino -I/home/audric/snap/arduino/61/.arduino15/packages/arduino/hardware/samd/1.8.13/variants/mkrgsm1400 -I/home/audric/snap/arduino/current/Arduino/libraries/MKRGSM/src -I/home/audric/snap/arduino/current/Arduino/libraries/Arduino_MKRGPS/src -I/home/audric/snap/arduino/61/.arduino15/packages/arduino/hardware/samd/1.8.13/libraries/Wire -I/home/audric/snap/arduino/61/.arduino15/packages/arduino/hardware/samd/1.8.13/libraries/SPI -I/home/audric/snap/arduino/current/Arduino/libraries/LoRa/src /tmp/arduino_build_968385/sketch/LoraDuplexMkr1400.ino.cpp -o /dev/null
Using cached library dependencies for file: /home/audric/snap/arduino/current/Arduino/libraries/MKRGSM/src/GPRS.cpp
Using cached library dependencies for file: /home/audric/snap/arduino/current/Arduino/libraries/MKRGSM/src/GSM.cpp
Using cached library dependencies for file: /home/audric/snap/arduino/current/Arduino/libraries/MKRGSM/src/GSMBand.cpp
Using cached library dependencies for file: /home/audric/snap/arduino/current/Arduino/libraries/MKRGSM/src/GSMClient.cpp
Using cached library dependencies for file: /home/audric/snap/arduino/current/Arduino/libraries/MKRGSM/src/GSMFileUtils.cpp
Using cached library dependencies for file: /home/audric/snap/arduino/current/Arduino/libraries/MKRGSM/src/GSMLocation.cpp
Using cached library dependencies for file: /home/audric/snap/arduino/current/Arduino/libraries/MKRGSM/src/GSMModem.cpp
Using cached library dependencies for file: /home/audric/snap/arduino/current/Arduino/libraries/MKRGSM/src/GSMPIN.cpp
Using cached library dependencies for file: /home/audric/snap/arduino/current/Arduino/libraries/MKRGSM/src/GSMSSLClient.cpp
Using cached library dependencies for file: /home/audric/snap/arduino/current/Arduino/libraries/MKRGSM/src/GSMScanner.cpp
Using cached library dependencies for file: /home/audric/snap/arduino/current/Arduino/libraries/MKRGSM/src/GSMServer.cpp
Using cached library dependencies for file: /home/audric/snap/arduino/current/Arduino/libraries/MKRGSM/src/GSMUdp.cpp
Using cached library dependencies for file: /home/audric/snap/arduino/current/Arduino/libraries/MKRGSM/src/GSMVoiceCall.cpp
Using cached library dependencies for file: /home/audric/snap/arduino/current/Arduino/libraries/MKRGSM/src/GSM_SMS.cpp
Using cached library dependencies for file: /home/audric/snap/arduino/current/Arduino/libraries/MKRGSM/src/Modem.cpp
Using cached library dependencies for file: /home/audric/snap/arduino/current/Arduino/libraries/MKRGSM/src/utility/GSMSocketBuffer.cpp
Using cached library dependencies for file: /home/audric/snap/arduino/current/Arduino/libraries/Arduino_MKRGPS/src/GPS.cpp
Using cached library dependencies for file: /home/audric/snap/arduino/current/Arduino/libraries/Arduino_MKRGPS/src/minmea/minmea.c
Using cached library dependencies for file: /home/audric/snap/arduino/current/Arduino/libraries/Arduino_MKRGPS/src/utility/SerialDDC.cpp
Using cached library dependencies for file: /home/audric/snap/arduino/61/.arduino15/packages/arduino/hardware/samd/1.8.13/libraries/Wire/Wire.cpp
Using cached library dependencies for file: /home/audric/snap/arduino/61/.arduino15/packages/arduino/hardware/samd/1.8.13/libraries/SPI/SPI.cpp
Using cached library dependencies for file: /home/audric/snap/arduino/current/Arduino/libraries/LoRa/src/LoRa.cpp
Generating function prototypes...
/home/audric/snap/arduino/61/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_SAMD_MKRGSM1400 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8052 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR GSM 1400\"" -DUSE_BQ24195L_PMIC -I/home/audric/snap/arduino/61/.arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/ -I/home/audric/snap/arduino/61/.arduino15/packages/arduino/tools/CMSIS-Atmel/1.2.0/CMSIS/Device/ATMEL/ -I/home/audric/snap/arduino/61/.arduino15/packages/arduino/hardware/samd/1.8.13/cores/arduino/api/deprecated -I/home/audric/snap/arduino/61/.arduino15/packages/arduino/hardware/samd/1.8.13/cores/arduino/api/deprecated-avr-comp -I/home/audric/snap/arduino/61/.arduino15/packages/arduino/hardware/samd/1.8.13/cores/arduino -I/home/audric/snap/arduino/61/.arduino15/packages/arduino/hardware/samd/1.8.13/variants/mkrgsm1400 -I/home/audric/snap/arduino/current/Arduino/libraries/MKRGSM/src -I/home/audric/snap/arduino/current/Arduino/libraries/Arduino_MKRGPS/src -I/home/audric/snap/arduino/61/.arduino15/packages/arduino/hardware/samd/1.8.13/libraries/Wire -I/home/audric/snap/arduino/61/.arduino15/packages/arduino/hardware/samd/1.8.13/libraries/SPI -I/home/audric/snap/arduino/current/Arduino/libraries/LoRa/src /tmp/arduino_build_968385/sketch/LoraDuplexMkr1400.ino.cpp -o /tmp/arduino_build_968385/preproc/ctags_target_for_gcc_minus_e.cpp
/snap/arduino/61/tools-builder/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /tmp/arduino_build_968385/preproc/ctags_target_for_gcc_minus_e.cpp
Compilation du croquis...
/home/audric/snap/arduino/61/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_SAMD_MKRGSM1400 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8052 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR GSM 1400\"" -DUSE_BQ24195L_PMIC -I/home/audric/snap/arduino/61/.arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/ -I/home/audric/snap/arduino/61/.arduino15/packages/arduino/tools/CMSIS-Atmel/1.2.0/CMSIS/Device/ATMEL/ -I/home/audric/snap/arduino/61/.arduino15/packages/arduino/hardware/samd/1.8.13/cores/arduino/api/deprecated -I/home/audric/snap/arduino/61/.arduino15/packages/arduino/hardware/samd/1.8.13/cores/arduino/api/deprecated-avr-comp -I/home/audric/snap/arduino/61/.arduino15/packages/arduino/hardware/samd/1.8.13/cores/arduino -I/home/audric/snap/arduino/61/.arduino15/packages/arduino/hardware/samd/1.8.13/variants/mkrgsm1400 -I/home/audric/snap/arduino/current/Arduino/libraries/MKRGSM/src -I/home/audric/snap/arduino/current/Arduino/libraries/Arduino_MKRGPS/src -I/home/audric/snap/arduino/61/.arduino15/packages/arduino/hardware/samd/1.8.13/libraries/Wire -I/home/audric/snap/arduino/61/.arduino15/packages/arduino/hardware/samd/1.8.13/libraries/SPI -I/home/audric/snap/arduino/current/Arduino/libraries/LoRa/src /tmp/arduino_build_968385/sketch/LoraDuplexMkr1400.ino.cpp -o /tmp/arduino_build_968385/sketch/LoraDuplexMkr1400.ino.cpp.o
Compiling libraries...
Compiling library "MKRGSM"
Utilisation du fichier déjà compilé : /tmp/arduino_build_968385/libraries/MKRGSM/GPRS.cpp.o
Utilisation du fichier déjà compilé : /tmp/arduino_build_968385/libraries/MKRGSM/GSMBand.cpp.o
Utilisation du fichier déjà compilé : /tmp/arduino_build_968385/libraries/MKRGSM/GSMUdp.cpp.o
Utilisation du fichier déjà compilé : /tmp/arduino_build_968385/libraries/MKRGSM/GSMServer.cpp.o
Utilisation du fichier déjà compilé : /tmp/arduino_build_968385/libraries/MKRGSM/GSMClient.cpp.o
Utilisation du fichier déjà compilé : /tmp/arduino_build_968385/libraries/MKRGSM/GSMScanner.cpp.o
Utilisation du fichier déjà compilé : /tmp/arduino_build_968385/libraries/MKRGSM/GSM.cpp.o
Utilisation du fichier déjà compilé : /tmp/arduino_build_968385/libraries/MKRGSM/GSMFileUtils.cpp.o
Utilisation du fichier déjà compilé : /tmp/arduino_build_968385/libraries/MKRGSM/GSMSSLClient.cpp.o
Utilisation du fichier déjà compilé : /tmp/arduino_build_968385/libraries/MKRGSM/GSMPIN.cpp.o
Utilisation du fichier déjà compilé : /tmp/arduino_build_968385/libraries/MKRGSM/GSMLocation.cpp.o
Utilisation du fichier déjà compilé : /tmp/arduino_build_968385/libraries/MKRGSM/GSMVoiceCall.cpp.o
Utilisation du fichier déjà compilé : /tmp/arduino_build_968385/libraries/MKRGSM/GSMModem.cpp.o
Utilisation du fichier déjà compilé : /tmp/arduino_build_968385/libraries/MKRGSM/GSM_SMS.cpp.o
Utilisation du fichier déjà compilé : /tmp/arduino_build_968385/libraries/MKRGSM/Modem.cpp.o
Utilisation du fichier déjà compilé : /tmp/arduino_build_968385/libraries/MKRGSM/utility/GSMSocketBuffer.cpp.o
Compiling library "Arduino_MKRGPS"
Utilisation du fichier déjà compilé : /tmp/arduino_build_968385/libraries/Arduino_MKRGPS/GPS.cpp.o
Utilisation du fichier déjà compilé : /tmp/arduino_build_968385/libraries/Arduino_MKRGPS/minmea/minmea.c.o
Utilisation du fichier déjà compilé : /tmp/arduino_build_968385/libraries/Arduino_MKRGPS/utility/SerialDDC.cpp.o
Compiling library "Wire"
Utilisation du fichier déjà compilé : /tmp/arduino_build_968385/libraries/Wire/Wire.cpp.o
Compiling library "SPI"
Utilisation du fichier déjà compilé : /tmp/arduino_build_968385/libraries/SPI/SPI.cpp.o
Compiling library "LoRa"
Utilisation du fichier déjà compilé : /tmp/arduino_build_968385/libraries/LoRa/LoRa.cpp.o
Compiling core...
Utilisation du fichier déjà compilé : /tmp/arduino_build_968385/core/variant.cpp.o
Utilisation du fichier déjà compilé : /tmp/arduino_build_968385/core/pulse_asm.S.o
Utilisation du fichier déjà compilé : /tmp/arduino_build_968385/core/WInterrupts.c.o
Utilisation du fichier déjà compilé : /tmp/arduino_build_968385/core/itoa.c.o
Utilisation du fichier déjà compilé : /tmp/arduino_build_968385/core/wiring_analog.c.o
Utilisation du fichier déjà compilé : /tmp/arduino_build_968385/core/pulse.c.o
Utilisation du fichier déjà compilé : /tmp/arduino_build_968385/core/wiring_private.c.o
Utilisation du fichier déjà compilé : /tmp/arduino_build_968385/core/startup.c.o
Utilisation du fichier déjà compilé : /tmp/arduino_build_968385/core/delay.c.o
Utilisation du fichier déjà compilé : /tmp/arduino_build_968385/core/wiring.c.o
Utilisation du fichier déjà compilé : /tmp/arduino_build_968385/core/cortex_handlers.c.o
Utilisation du fichier déjà compilé : /tmp/arduino_build_968385/core/hooks.c.o
Utilisation du fichier déjà compilé : /tmp/arduino_build_968385/core/USB/samd21_host.c.o
Utilisation du fichier déjà compilé : /tmp/arduino_build_968385/core/wiring_digital.c.o
Utilisation du fichier déjà compilé : /tmp/arduino_build_968385/core/wiring_shift.c.o
Utilisation du fichier déjà compilé : /tmp/arduino_build_968385/core/compact/dtostrf.c.o
Utilisation du fichier déjà compilé : /tmp/arduino_build_968385/core/new.cpp.o
Utilisation du fichier déjà compilé : /tmp/arduino_build_968385/core/abi.cpp.o
Utilisation du fichier déjà compilé : /tmp/arduino_build_968385/core/WMath.cpp.o
Utilisation du fichier déjà compilé : /tmp/arduino_build_968385/core/api/Common.cpp.o
Utilisation du fichier déjà compilé : /tmp/arduino_build_968385/core/Tone.cpp.o
Utilisation du fichier déjà compilé : /tmp/arduino_build_968385/core/api/PluggableUSB.cpp.o
Utilisation du fichier déjà compilé : /tmp/arduino_build_968385/core/Reset.cpp.o
Utilisation du fichier déjà compilé : /tmp/arduino_build_968385/core/api/IPAddress.cpp.o
Utilisation du fichier déjà compilé : /tmp/arduino_build_968385/core/main.cpp.o
Utilisation du fichier déjà compilé : /tmp/arduino_build_968385/core/api/Stream.cpp.o
Utilisation du fichier déjà compilé : /tmp/arduino_build_968385/core/Uart.cpp.o
Utilisation du fichier déjà compilé : /tmp/arduino_build_968385/core/api/String.cpp.o
Utilisation du fichier déjà compilé : /tmp/arduino_build_968385/core/USB/USBCore.cpp.o
Utilisation du fichier déjà compilé : /tmp/arduino_build_968385/core/USB/CDC.cpp.o
Utilisation du fichier déjà compilé : /tmp/arduino_build_968385/core/api/Print.cpp.o
Utilisation du fichier déjà compilé : /tmp/arduino_build_968385/core/SERCOM.cpp.o
Utilisation du fichier déjà compilé : /tmp/arduino_build_968385/core/core.a
Archivage du noyau construit (mise en cache) dans : /tmp/arduino_cache_685531/core/core_arduino_samd_mkrgsm1400_5215c868484212790c1bb706f88d8889.a
Linking everything together...
/home/audric/snap/arduino/61/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -L/tmp/arduino_build_968385 -Os -Wl,--gc-sections -save-temps -T/home/audric/snap/arduino/61/.arduino15/packages/arduino/hardware/samd/1.8.13/variants/mkrgsm1400/linker_scripts/gcc/flash_with_bootloader.ld -Wl,-Map,/tmp/arduino_build_968385/LoraDuplexMkr1400.ino.map --specs=nano.specs --specs=nosys.specs -mcpu=cortex-m0plus -mthumb -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -o /tmp/arduino_build_968385/LoraDuplexMkr1400.ino.elf /tmp/arduino_build_968385/sketch/LoraDuplexMkr1400.ino.cpp.o /tmp/arduino_build_968385/libraries/MKRGSM/GPRS.cpp.o /tmp/arduino_build_968385/libraries/MKRGSM/GSM.cpp.o /tmp/arduino_build_968385/libraries/MKRGSM/GSMBand.cpp.o /tmp/arduino_build_968385/libraries/MKRGSM/GSMClient.cpp.o /tmp/arduino_build_968385/libraries/MKRGSM/GSMFileUtils.cpp.o /tmp/arduino_build_968385/libraries/MKRGSM/GSMLocation.cpp.o /tmp/arduino_build_968385/libraries/MKRGSM/GSMModem.cpp.o /tmp/arduino_build_968385/libraries/MKRGSM/GSMPIN.cpp.o /tmp/arduino_build_968385/libraries/MKRGSM/GSMSSLClient.cpp.o /tmp/arduino_build_968385/libraries/MKRGSM/GSMScanner.cpp.o /tmp/arduino_build_968385/libraries/MKRGSM/GSMServer.cpp.o /tmp/arduino_build_968385/libraries/MKRGSM/GSMUdp.cpp.o /tmp/arduino_build_968385/libraries/MKRGSM/GSMVoiceCall.cpp.o /tmp/arduino_build_968385/libraries/MKRGSM/GSM_SMS.cpp.o /tmp/arduino_build_968385/libraries/MKRGSM/Modem.cpp.o /tmp/arduino_build_968385/libraries/MKRGSM/utility/GSMSocketBuffer.cpp.o /tmp/arduino_build_968385/libraries/Arduino_MKRGPS/GPS.cpp.o /tmp/arduino_build_968385/libraries/Arduino_MKRGPS/minmea/minmea.c.o /tmp/arduino_build_968385/libraries/Arduino_MKRGPS/utility/SerialDDC.cpp.o /tmp/arduino_build_968385/libraries/Wire/Wire.cpp.o /tmp/arduino_build_968385/libraries/SPI/SPI.cpp.o /tmp/arduino_build_968385/libraries/LoRa/LoRa.cpp.o /tmp/arduino_build_968385/core/variant.cpp.o -Wl,--start-group -L/home/audric/snap/arduino/61/.arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Lib/GCC/ -larm_cortexM0l_math -lm /tmp/arduino_build_968385/core/core.a -Wl,--end-group
/home/audric/snap/arduino/61/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-objcopy -O binary /tmp/arduino_build_968385/LoraDuplexMkr1400.ino.elf /tmp/arduino_build_968385/LoraDuplexMkr1400.ino.bin
/home/audric/snap/arduino/61/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-objcopy -O ihex -R .eeprom /tmp/arduino_build_968385/LoraDuplexMkr1400.ino.elf /tmp/arduino_build_968385/LoraDuplexMkr1400.ino.hex
Utilisation de la bibliothèque MKRGSM version 1.5.0 dans le dossier: /home/audric/snap/arduino/current/Arduino/libraries/MKRGSM
Utilisation de la bibliothèque Arduino_MKRGPS version 1.0.0 dans le dossier: /home/audric/snap/arduino/current/Arduino/libraries/Arduino_MKRGPS
Utilisation de la bibliothèque Wire version 1.0 dans le dossier: /home/audric/snap/arduino/61/.arduino15/packages/arduino/hardware/samd/1.8.13/libraries/Wire
Utilisation de la bibliothèque SPI version 1.0 dans le dossier: /home/audric/snap/arduino/61/.arduino15/packages/arduino/hardware/samd/1.8.13/libraries/SPI
Utilisation de la bibliothèque LoRa version 0.8.0 dans le dossier: /home/audric/snap/arduino/current/Arduino/libraries/LoRa
/home/audric/snap/arduino/61/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-size -A /tmp/arduino_build_968385/LoraDuplexMkr1400.ino.elf
Le croquis utilise 74036 octets (28%) de l'espace de stockage de programmes. Le maximum est de 262144 octets.
Les variables globales utilisent 5044 octets (15%) de mémoire dynamique, ce qui laisse 27724 octets pour les variables locales. Le maximum est de 32768 octets.
Redémarrage forcé en cours en 1200bps ouvert/fermé sur le port /dev/ttyACM0
PORTS {/dev/ttyACM0, /dev/ttyUSB0, } / {/dev/ttyACM0, /dev/ttyUSB0, } => {}
Uploading using selected port: /dev/ttyACM0
/home/audric/snap/arduino/61/.arduino15/packages/arduino/tools/bossac/1.7.0-arduino3/bossac -i -d --port=ttyACM0 -U true -i -e -w -v /tmp/arduino_build_968385/LoraDuplexMkr1400.ino.bin -R
No device found on ttyACM0
Set binary mode
Send auto-baud
Une erreur est survenue lors du transfert du croquis
Set binary mode
