Mkr 1500 connected to nb network does not stay running for more than 24 hours connected without a hard resett
I am wondering if anyone is having success with the mkr 1500.
I have not successfully had it running continuously in either straight connection to cell provider or the Blynk app for longer than 24 hours without the need for a hard reset.
I have tried a new lipo, without lipo attached, running straight usb, usb with solid 6v. Just connected to cell provider, deep sleep etc. Previously I had been using the same Sara module on the particle boron with great success. The mkr from all the topics here seem to be a bit under developed and or under supported in my opinion. I hope like most arduino boards that this one is eventually as good.
I have purchased the firmware shield from ebay, from the poster on this forum that sells them. It is a couple weeks away..
If anyone has a working sketch or solution/idea I’m all ears.
Post your code in tags
I hope this has the tags. Preformatted text
#include "ArduinoLowPower.h"
#include <MKRNB.h>
#include <BlynkSimpleMKRNB.h>
NBClient client;
GPRS gprs;
NB nbAccess;
#define BLYNK_PRINT Serial
// You should get Auth Token in the Blynk App.
// Go to the Project Settings (nut icon).
char auth[] = "";
// Your SIM credential
// Leave empty, if missing pin
char pin[]  = "";
float maxBatteryVoltage = 4.3;
   pinMode(LED_BUILTIN, OUTPUT);
  Blynk.begin(auth, nbAccess, gprs, client , pin);
 int adcReading = analogRead(ADC_BATTERY);
  float batteryVoltage = adcReading * (maxBatteryVoltage / 1023.0);
  float percentage = (batteryVoltage / maxBatteryVoltage) * 100;
  Serial.print(batteryVoltage);
  Serial.print(percentage);
  Serial.println(batteryVoltage);
   Blynk.run();
    Blynk.virtualWrite(V6, percentage);
    Blynk.virtualWrite(V5, batteryVoltage);
digitalWrite(LED_BUILTIN, HIGH);
  digitalWrite(LED_BUILTIN, LOW);
  Serial.println("Sleeping");
 nbAccess.shutdown();
delay(3000);
  Serial.println("Modem Off");
 delay(5 * 60000);
Your topic has been moved to a more suitable location on the forum. Installation and Troubleshooting is not for problems with (nor for advice on) your project :wink: See About the Installation & Troubleshooting category.
This is directly based on the work here:
https://forum.arduino.cc/t/fault-low-signal-tolerant-sketch-for-use-with-thingspeak/1004324
I modified it for Blynk.
You will need to create a Blynk machine with 5 virtual pins. You will also need to write "ledon" to Pin V5.
  This sketch works with the MKR NB 1500 without the need for the MKRNB library.
  It updates blynk DataStreams using http GET every 10 mins.
  Pin V1 = Battery Voltage
  Pin V2 = Example data(4)
  Pin V3 = Modem Reset Count
  Pin V4 = Modem signal, rsrq in dB
  It also reads command from Pin V5 using http GET. In the sample program I have provided,
  a command of "ledon" will turn on the onboard LED and "ledoff" will turn off the onboard LED.
  You can use another arduino or a desktop/android app like Postman to send commands
  to Pin V5.
  With this program, these commands are only updated when the blynk channel is updated.
  By default, it updates every 10 mins. Therefore, it only executes commands every 10 mins.
  This can be easily changed by changing the blynkPostInterval.
#include <avr/dtostrf.h>
const char apn[] = "hologram";//"m2m64.com.attz";
const char simPIN[] = "1234";//If the sim card needs a PIN, this will be used.
  Network profile ID, see AT Manual Appendix C.4:
  C.4  SARA-R410M-02B Americas MNO profile tables
  Network     Profile ID
  Undefined     0
  AT&T          2
  Verizon       3(won't register unless device is approved by Verizon)
  T-mobile US   5
  Sprint        8
  Telus         21
const char networkProfile[] = "2";//Network profile ID
const char blynkToken[] = "tokennnnnnnn";//blynk Auth Token
int blynkCommandField = 5; //blynk Pin used to read commands
bool mcuLowPower = false; //If true, the Microcontroller will be put into sleep after each post.
  Blynk URL varies depending on location. Copied from api reference material:
  Due to current GeoDNS settings you need to put server address with suffix manually depending on your region:
  https://fra1.blynk.cloud/ – Frankfurt
  https://lon1.blynk.cloud/ – London
  https://ny3.blynk.cloud/ – New York
  https://sgp1.blynk.cloud/ – Singapore
  https://blr1.blynk.cloud/ – Bangalore
  The server region could be found in the right bottom corner of the web interface.
const char blynkUrl[] = "ny3.blynk.cloud";//Depends on location, see above
const unsigned int blynkPort = 80;//80 or 443 for TLS
const unsigned long blynkPostInterval = 600000;
//System variables below ------------------------------------
unsigned long lastBlynkPostTime = 0;
unsigned long commandStartTime = 0;
unsigned long delayStartTime = 0;
unsigned long postStartTime = 0;
int resetCount = 0;
int responsePosition = 0;
int sendCommandStage = 0;
int stage = 0;
int timeoutCount = 0;
int socket = -1;
int socketErrorCount = 0;
int httpErrorCount = 0;
int loopCount = 0;
int rsrq_dB = 0;
int dnsCheckPeriod = 0;
int dnsCheckCount = 0;
bool modemSetupFlag = false;
bool blynkSuccessFlag = false;
bool modemHardResetAndPowerOnPending = true;
bool modemReset = false;
bool modemSoftResetPending = false;
bool responseError = false;
bool blynkCommand = false;
bool modemPoweredUp = false;
char response[1024];
char formattedCommand[350];
char formattedHttp[350];
char blynkIp[15];
char socketCloseIndicator[10];
  pinMode(SARA_PWR_ON, INPUT);
  pinMode(SARA_RESETN, INPUT);
  SerialSARA.begin(115200);
  dnsCheckPeriod = round(3600000 / blynkPostInterval);
  if (dnsCheckPeriod < 1) {
    dnsCheckPeriod = 1;
  dnsCheckCount = dnsCheckPeriod + 1;
  if (timeoutCount > 20) {
    timeoutCount = 0;
    resetCount++;
    modemReset = true;
  if (modemHardResetAndPowerOnPending) {
    modemHardResetAndPowerOn();
  if (responsePosition > 1023) {
    Serial.print(response);
    memset(response, 0, sizeof(response));
  if (SerialSARA.available()) {
    response[responsePosition++] = SerialSARA.read();
  if (!modemSetupFlag && !modemHardResetAndPowerOnPending) {
    modemSetup();
  if (!mcuLowPower && millis() - lastBlynkPostTime > blynkPostInterval) {
    lastBlynkPostTime = millis();
  if (!modemPoweredUp) {
  if (!blynkSuccessFlag && modemSetupFlag && !modemHardResetAndPowerOnPending) {
    rawHttpPost();
void sendCommand(const char command[350], unsigned long timeout, bool acceptError) {
  if (sendCommandStage == 0) {
    Serial.println(command);
    SerialSARA.println(command);
    commandStartTime = millis();
    sendCommandStage++;
    loopCount = 0;
  if (sendCommandStage == 1) {
    loopCount++;
    if (loopCount > 1000) {
      loopCount = 0;
      if (strstr(response, "\nOK\r") != NULL || strstr(response, "\r\n@") != NULL) {
        delayStartTime = millis();
        sendCommandStage++;
      if (strstr(response, "+CME ERROR") != NULL) {
        responseError = true;
        sendCommandStage++;
    if (millis() - commandStartTime > timeout) {
      Serial.println(response);
      Serial.println("Response timeout");
      stage = 0;
      timeoutCount++;
  if (sendCommandStage == 2) {
    if (millis() - delayStartTime > 25) {
      timeoutCount = 0;
      if (responseError && !acceptError) {
        stage = 0;
      else {
        stage++;
void modemHardResetAndPowerOn() {
  if (stage == 0) {
    if (modemReset) {
      Serial.println("Modem resetting...");
      pinMode(SARA_RESETN, OUTPUT);
      digitalWrite(SARA_RESETN, HIGH);//Logic high on Arduino pin = logic low on SARA R4
      stage++;
    else {
      stage = 2;
  if (stage == 1) {
    if (millis() - delayStartTime > 12000) {
      stage++;
  if (stage == 2) {
    if (millis() - delayStartTime > 500) {
      pinMode(SARA_PWR_ON, OUTPUT);
      digitalWrite(SARA_PWR_ON, HIGH);//Logic high on Arduino pin = logic low on SARA R4
      stage++;
  if (stage == 3) {
      Serial.println("Modem on");
      stage++;
  if (stage == 4) {
    if (millis() - delayStartTime > 5000) {
      Serial.println("Reset and/or Power On complete");
      stage = 0;
      modemReset = false;
      modemHardResetAndPowerOnPending = false;
      modemPoweredUp = true;
void modemSetup() {
  if (stage == 0) {
    sendCommand("ATV1", 1000, true);
  if (stage == 1) {
    sendCommand("AT+IPR=115200", 1000, true);//Baud rate set
  if (stage == 2) {
    sendCommand("ATE0", 1000, true);//Echo off
  if (stage == 3) {
    sendCommand("AT+CMEE=2", 10000, true);
  if (stage == 4) {
    sendCommand("AT+CPIN?", 10000, true);
  if (stage == 5) {
    if (strstr(response, "SIM PIN") != NULL) {
      sprintf(formattedCommand, "AT+CPIN=\"%s\"", simPIN);
      stage++;
    else {
      stage = 7;
  if (stage == 6) {
    sendCommand(formattedCommand, 10000, true);
  if (stage == 7) {
    if (modemSoftResetPending == true) {
      sendCommand("AT+CFUN=15", 180000, true);
    else {
      stage = 10;
  if (stage == 8) {
    stage++;
  if (stage == 9) {
      stage = 0;
  if (stage == 10) {
    sendCommand("AT+UMNOPROF?", 1000, true);
  if (stage == 11) {
    if (strstr(response, networkProfile) == NULL) {
      stage++;
    else {
      stage = 16;
  if (stage == 12) {
    sendCommand("AT+CFUN=0", 180000, true);
  if (stage == 13) {
    sprintf(formattedCommand, "AT+UMNOPROF=%s", networkProfile);
    stage++;
  if (stage == 14) {
    sendCommand(formattedCommand, 1000, true);
  if (stage == 15) {
    modemSoftResetPending = true;
    stage = 7;
  if (stage == 16) {
    sendCommand("AT+CGDCONT?", 1000, true);
  if (stage == 17) {
    if (strstr(response, apn) == NULL || strstr(response, "IP") == NULL) {
      stage++;
    else {
      stage = 22;
  if (stage == 18) {
  if (stage == 19) {
    sprintf(formattedCommand, "AT+CGDCONT=1,\"IP\",\"%s\"", apn);
    stage++;
  if (stage == 20) {
  if (stage == 21) {
    stage = 7;
  if (stage == 22) {
    sendCommand("AT+CPSMS?", 1000, true);
  if (stage == 23) {
    if (strstr(response, "+CPSMS:0") == NULL) {
      stage++;
    else {
      stage = 27;
  if (stage == 24) {
  if (stage == 25) {
    sendCommand("AT+CPSMS=0", 10000, true);
  if (stage == 26) {
    stage = 7;
  if (stage == 27) {
    sendCommand("AT+COPS=0", 10000, true);
  if (stage == 28) {
    sendCommand("AT+CEREG=0", 1000, true);
  if (stage == 29) {
    sendCommand("AT+USOCLCFG=1", 1000, true);
  if (stage == 30) {
    sendCommand("AT+UPSV=4", 1000, true);
  if (stage == 31) {
    modemSetupFlag = true;
    stage = 0;
void rawHttpPost() {
  if (stage == -1) {
    postStartTime = millis();
    stage++;
  if (stage == 0) {
  if (stage == 1) {
    sendCommand("AT+CEREG?", 1000, false);
  if (stage == 2) {
    if (strstr(response, ",1") != NULL || strstr(response, ",5") != NULL) {
      stage++;
      Serial.println("Registered");
    else {
      if (millis() - commandStartTime > 500) {
        stage--;
  if (stage == 3) {
    sendCommand("AT+CGATT?", 1000, false);
  if (stage == 4) {
    if (strstr(response, "+CGATT: 1") != NULL) {
      stage++;
      Serial.println("Attached");
    else {
        stage--;
  if (stage == 5) {
    sendCommand("AT+CGACT?", 1000, false);
  if (stage == 6) {
    if (strstr(response, ",1") != NULL) {
      stage++;
      Serial.println("Context Activated");
    else {
        stage--;
  if (stage == 7) {
    sendCommand("AT+CESQ", 1000, false);
  if (stage == 8) {
    char *responsePointer;
    int rsrq = 0;
    responsePointer = strstr(response, "+CESQ:");
    if (responsePointer != NULL) {
      int rsrq1 = responsePointer[21] - '0' ;
      if (responsePointer[22] != ',') {
        int rsrq2 = responsePointer[22] - '0' ;
        rsrq = (rsrq1 * 10) + rsrq2;
        if (responsePointer[23] != ',') {
          rsrq = 0;
      else {
        rsrq = rsrq1;
      rsrq_dB = -20 + (.5 * rsrq);
      Serial.print("Signal RSRQ:");
      Serial.print(rsrq_dB);
      Serial.println("dB (closer to zero is better)");
      socket = 0;
      stage++;
    else {
      stage = 0;
  if (stage == 9) {
    sprintf(formattedCommand, "AT+USOCL=%i,1", socket);
    stage++;
  if (stage == 10) {
    sendCommand(formattedCommand, 150000, true);
  if (stage == 11) {
    socket++;
    if (socket <= 6) {
      stage = stage - 2;
    else {
      socket = -1;
      stage++;
  if (stage == 12) {
    if (dnsCheckCount >= dnsCheckPeriod) {
      sprintf(formattedCommand, "AT+UDNSRN=0,\"%s\"", blynkUrl);
      stage++;
    else {
      dnsCheckCount++;
      stage = stage + 3;
  if (stage == 13) {
  if (stage == 14) {
    int blynkIpPosition = 0;
    int pointerPosition = 10;
    responsePointer = strstr(response, "+UDNSRN:");
      while (responsePointer[pointerPosition] != '"' && blynkIpPosition <= 14) {
        blynkIp[blynkIpPosition] = responsePointer[pointerPosition];
        blynkIpPosition++;
        pointerPosition++;
      dnsCheckCount = 0;
      stage++;
    else {
      stage = 0;
  if (stage == 15) {
    sendCommand("AT+USOCR=6", 120000, true);
  if (stage == 16) {
    if (responseError) {
      stage = 0;
    else {
      responsePointer = strstr(response, "+USOCR:");
        socket = responsePointer[8] - '0' ;
        int securitySetting = 0;
        if ( blynkPort == 443) {
          securitySetting = 1;
        sprintf(formattedCommand, "AT+USOSEC=%i,%i", socket, securitySetting);
        sprintf(socketCloseIndicator, "+UUSOCL: %i", socket);
        stage++;
      else {
        stage = 0;
  if (stage == 17) {
    sendCommand(formattedCommand, 1000, false);
  if (stage == 18) {
    sprintf(formattedCommand, "AT+USOCO=%i,\"%s\",%i", socket, blynkIp, blynkPort);
    stage++;
  if (stage == 19) {
  if (stage == 20) {
      socketErrorCount++;
      stage = 0;
      if (socketErrorCount > 10) {
    else {
      stage++;
  if (stage == 21) {
    int formattedHttpSize = 0;
    if (blynkCommand) {
      formattedHttpSize = sprintf(formattedHttp, "GET /external/api/get?token=%s&v%i HTTP/1.1\r\n"
                                  "Host: %s\r\n\r\n", blynkToken, blynkCommandField, blynkUrl);
    else {
      int data = 4;
      float batVoltage = analogRead(ADC_BATTERY) * 3.3 / 1023.0 * 1.275;//1.275 is derived from ADC_BATTERY voltage divider
      char batVoltageCharArray[6];
      dtostrf(batVoltage, 0, 3, batVoltageCharArray);
      formattedHttpSize = sprintf(formattedHttp, "GET /external/api/batch/update?token=%s&v1=%s&v2=%i&v3=%i&v4=%i HTTP/1.1\r\n"
                                  "Host: %s\r\n\r\n", blynkToken, batVoltageCharArray, data, resetCount, rsrq_dB, blynkUrl);
    sprintf(formattedCommand, "AT+USOWR=%i,%i", socket, formattedHttpSize);
    stage++;
  if (stage == 22) {
    sendCommand(formattedCommand, 120000, false);
  if (stage == 23) {
    if (millis() - delayStartTime > 50) {
      stage++;
  if (stage == 24) {
    sendCommand(formattedHttp, 120000, false);
  if (stage == 25) {
    responsePointer = strstr(response, "+USOWR:");
      if (responsePointer[10] - '0' != 0 ) {
        loopCount = 0;
        stage++;
      else {
        stage = 0;
    else {
      stage = 0;
  if (stage == 26) {
    loopCount++;
      loopCount = 0;
      responsePointer = strstr(response, "+UUSORD:");
        sprintf(formattedCommand, "AT+USORD=%i,1024", socket);
        Serial.println(responsePointer);
        stage++;
      responsePointer = strstr(response, socketCloseIndicator);
        stage = 0;
    if (millis() - delayStartTime > 90000) {
      stage = 0;
  if (stage == 27) {
      stage++;
  if (stage == 28) {
    sendCommand(formattedCommand, 5000, false);
  if (stage == 29) {
    if (strstr(response, "HTTP/1.1 200") != NULL) {
      char *endPointer;
      int contentLength = 0;
      int receivedContentLength = 0;
      int ones;
      int tens;
      int hundreds;
      responsePointer = strstr(response, "content-length");
        hundreds = responsePointer[16] - '0';
        if (responsePointer[17] != '\r') {
          tens = responsePointer[17] - '0';
          if (responsePointer[18] != '\r') {
            ones = responsePointer[18] - '0';
            contentLength = (100 * hundreds) + (10 * tens) + ones;
          else {
            contentLength = (10 * hundreds) + tens;
        else {
          contentLength = hundreds;
        Serial.print("Http Header Content Length:");
        Serial.println(contentLength);
        responsePointer = strstr(responsePointer, "\r\n\r\n");
          endPointer = strrchr(responsePointer, '"');
          if (endPointer != NULL) {
            receivedContentLength = endPointer - responsePointer - 4;
            Serial.print("Received Content Length:");
            Serial.println(receivedContentLength);
            if (contentLength == receivedContentLength) {
              if (!blynkCommand) {
                blynkCommand = true;
                stage = 21;
                httpErrorCount = 0;
              else {
                stage++;
                httpErrorCount = 0;
                if (strstr(responsePointer, "ledon") != NULL) {
                if (strstr(responsePointer, "ledoff") != NULL) {
            else {
              stage = 0;
          else {
            stage = 0;
        else {
          stage = 0;
      else {
        stage = 0;
    else {
      httpErrorCount++;
      stage = 0;
      if (httpErrorCount > 10) {
        stage = 0;
        httpErrorCount = 0;
  if (stage == 30) {
    stage++;
  if (stage == 31) {
  if (stage == 32) {
    socket = -1;
    if (mcuLowPower) {
      stage = -1;
      unsigned long postDuration = millis() - postStartTime;
      while (postDuration > blynkPostInterval) {
        postDuration = postDuration - blynkPostInterval;
      Serial.println("MCU sleep until next update...");
      LowPower.sleep(blynkPostInterval - postDuration);
    else {
      stage = 0;
      blynkSuccessFlag = true;
This will require updated modem firmware.
Thank you for your help and time. Can’t wait to use your code. Mkr programming shield arrived today. Once I have worked it out for updating the firmware, and loaded your code , I will update.
Any luck?
